VSA off on 19s?
steeez
vsa = vehical stability assistance.. kinda like traction. with normal driving you wouldnt wana turn the vsa off
heres a thread about what vsa is and situations where u would want them off.. like racing
https://acurazine.com/forums/car-parts-sale-361/fs-xbox-games-%2410-up-125306/
https://acurazine.com/forums/showthread.php?t=125306
No, you don't have to turn it off.
It will always come back on when you start the engine, even if you had shut it off previously.
If your wheel/tire diameter changed from the stock setup to any major degree, the ABS, and VSA systems may not operate as intended, though.
Full of water...
only if you decide to run different sizes, like 18s in the front and 19s in the back, or 18s on the left and 19s on the right, or...i think you get the picture. leave it on.
King of NYC
If the external diameter of the wheel is not off by much it won't affect VSA. When you go up in diameter you usually go down in aspect ratio to make up the difference and add to asthetics and performance. The external diameter is still around the same give or take an inch.
If you put on some 4X4 tires or some wagon wheels on your car then you definitely will affect the VSA. Also as said different diameters front and back will make a difference too, but your car is not a Lamborghini, don't do that.
Should if i turn the VSA off if I am running 19 X 8.5 on four wheels? What would happen if I leave it on while normal driving? Thanx!
Full of water...
Trolling Canuckistan
You only would shut the VSA off if you have 2 different sized wheels on the DRIVE wheels, essentially if you are using the donut tire on the front wheels or if you had a issue with one of the 19" rims and had 1 stock rim on in it's place.
The issue you face if you have the VSA on and have the spare on the front is premature wear of the brake pads due to constant (unnecessary) application of the ABS system due to a confused VSA system.
Jamus22
06-11-2023 10:08 AM
