VSA/check engine light
Old Aug 28, 2013 | 06:45 PM
JVisco88's Avatar
I have an 06 TL and I was getting the three lights, VSA, check engine, and the /!\ one. I have gotten the codes which are 83-1 ecm/pcm relation failure and p2138 which has to do with the APP sensor. Now I have replaced the app sensor about three months ago and everything was fine until today. So what is the ecm/pcm relation failure and how do I fix it?
Old Nov 8, 2013 | 09:48 AM
Josh73's Avatar
i am currently having this same problem, and then last night about 2 hrs after i got all the codes the check light went off, i also got a 86-1 controller area network relation malfunction, i am gonna replace the app sensor today and see what happens.
Old Nov 8, 2013 | 11:28 AM
Majofo's Avatar
Replace the APP sensor. Check the connections on each end. If 86-1 doesn't go away, you'll need the HDS or a high-end reader to clear it.
Old Nov 8, 2013 | 11:35 AM
Josh73's Avatar
alright, now where can i get the app sensor at a good price? idk if i should go to advanced auto or online?
Old Nov 8, 2013 | 11:48 AM
Majofo's Avatar
acuraoemparts.com $136 + S/H
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
