Vinyl grill ..
Old Apr 14, 2011 | 12:43 AM
jbreezyxxo's Avatar
Unhappy Vinyl grill ..
anyone know any good diy videos on youtube on how to apply the vinyl on the front grill? i have honda day on sunday and im going crazy lol. suggestions would help .. thanks !!
Old Apr 14, 2011 | 09:37 AM
Dino81's Avatar
Save urself the heaDache and do it right the first time. Take off the bumper, disassemble the entire grille. Wrap each piece individually...use a hair dryer to heat the vinyl, that is key to streaching it and making it lay nice.
Clean all grille pieces to be wrapped with alcohol (ipa). Use a couple drops of dawn in a spray bottle of water for lube. A rubber squeegee, or a credit card to smooth out any bubbles. Also a pin comes in handy for any little bubbles left. Just poke a small hole, squeege out water/air...
Most importantly...patience..it'll take a while to make it look good, especially if its ur first time....hope this helps...good luck bro!
Old Apr 14, 2011 | 09:46 AM
1islandparadise's Avatar
The vinyl is a dry vinyl and you do NOT use water. Use A LOT of heat and stretch the vinyl and push it into your grill. I've done a couple grills myself and it really isn't that hard after a few times playing with vinyl! Good luck!
Old Apr 14, 2011 | 09:50 AM
SharksBreath's Avatar
BANNED
good luck girl!
fixed.
^this.
Old Apr 14, 2011 | 10:00 AM
D Loke's Avatar
Anyone tired this with the 3M carbon fiber-looking stuff?
Old Apr 14, 2011 | 10:02 AM
Dino81's Avatar
Hmmm...I've always used a little water...turned out fine...ill try without next time.
Old Apr 14, 2011 | 10:11 AM
BANNED
yeah and it works the same as the other 3M colors.
Old Apr 14, 2011 | 10:27 AM
D Loke's Avatar
Awesome... my buddy was gonna get some and have leftover so I figured I'd try it, I just didn't know if it were as plyable as the regular vinyl.
Old Apr 14, 2011 | 10:32 AM
BANNED
^yup just be careful with the CF bc if you heat it and stretch it too much/often, it tends to lose it's "carbon fiber" pattern.
Old Apr 14, 2011 | 10:40 AM
D Loke's Avatar
Thanks for the heads up.
Old Apr 15, 2011 | 12:13 AM
jbreezyxxo's Avatar
thanks guys !
Old Apr 15, 2011 | 07:43 AM
DeathMetal's Avatar
Fearless DIY Guy
Which portions are you looking to do? I'm 20 mins from Philly and may be able to help you out on this, it'd take me 30 mins for the install.
Old Apr 15, 2011 | 07:39 PM
rico651's Avatar
just did the piece attached to the hood last night. fairly easy to stretch/mold when its hot. i just mainly used my fingers instead of the plastic squeegee, i found that my fingers produce less scratches..
Old Apr 17, 2011 | 11:36 AM
07tl-s6spd's Avatar
Chapter Leader (Central New Jersey)
^^^your squeegee should have a piece of felt on it...produces no scratches
Old Apr 17, 2011 | 12:05 PM
DeathMetal's Avatar
Fearless DIY Guy
The grille can be done as a dry wrap only with no need to "squeege"
Old Apr 17, 2011 | 01:17 PM
07tl-s6spd's Avatar
^^i know that...even with a dry install you can still use one...no matter how big or small the job is...
quanaman
Jan 9, 2023 07:33 PM
Acura604
2G RDX Photograph Gallery
27
Oct 8, 2020 09:24 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
rhdune16
Sep 28, 2015 11:31 AM
scionxb3003
Sep 22, 2015 05:28 PM
