vibration exists
well today i noticed it for the first since ive had my car (1month and 1 week) it happens around 50-55mph...i never noticed it before but today i did....it doesnt bother me that much...probobly wouldnt have noticed it if i didnt hear about it on this board.....
well anyways..whats the deal with the vibration...is acura replacing these tires only for the ppl that have the vibration?
Woundering what you guys did when u experienced this?
and by the way the date on the tires is 50/03 so i guess end of 03
thanks
thanks
I have slightly vibration from this tranny/engine/exhaust resonance/whatever it is at 50-55 MPH/5th gear/1500 RPM. This is only vibration I have in my 04TL.
I'm not going to ask for so-called-new-design EL42s. Dealers may require to run some diagnosis before swaping your old EL42s, I don't know what is the standard by Acura, but it may take some time to get the new EL42s. I don't want to waste my time and listen to another BS from dealers, so probably may just get my new own tires before the start of 05 Winter.
Does someone saying these NEW EL42s experience vibration... this would be terrible...
i have new el42's no vibrations. the weather has been cold here and the car has been sitting overnight everyday. i get up early in the morning and drive with the tires cold and get up to 50mph pretty quickly, so the tires haven't warmed up yet. there is no vibration.
if you bring it to the dealer they will probably have to diagnose the problem before they give you new tires. if its crappy tires then definitely follow thru and get new ones from dealer. even if you have to go through some trouble go get it. if you are still uncomfortable with them after you get them take the new tires to a local tire shop and trade them in and pay the difference for some michellin pilot sports. you'll probably get a really good credit for the brand new tires. so the difference in cost will not be that bad and you will have a great set of tires with awesome performance.
I think I'm among the lucky. I have a 5000 vin (bought back in October) and have no vibrations with the EL42's. Of course now having said that my tires will probably summarily disintegrate as I hit 50 on the freeway.
I have lost the battle with my dealer to swap my replacement EL42's for Michelins (or anything else), and they will be installed this afternoon. I hope after I drive them tomorrow morning I can report that the vibration problem is solved. Will keep you posted.
Re: vibration exists
thanks
thanks
So I have a question, I have 3 tires which have 0304 and the other has 0204. Does this matter? Also, I do get a vibration when I hit 50mph everytime I am driving. I have only had my car for a week and was hoping it would go away.
Hopefully it is just a rebalance of the tires.
Re: Re: vibration exists
Originally posted by Tread
Ravi, don't let acura bully you, they know of this 1500RPM vibration that occurs at 50-55mph, it is seperate from the tires/wheels and they have no fix for it. Note that new tires and reballancing originals do not fix the issue.
Ravi,
Several posts were deleted when they had a system problem, but Acura was telling people that it is an exhaust resonance issue and this vibrates the car at 1500rpms which is around 50-60mph. Also at this point there is a increase in sound level (TOV.net measured 6dB increase) in the car.
Search for 1500, you will see complaints about this, unfortunately the posts that detailed this are gone (maybe it was Acura??) due to the system issue.
Also at MDX.org, they are having a simmilar exhaust resonance issue at 2000rpms, so it is believable.
I have not gotten mine fixed, instead they are saying it is "Normal for this car"
I hope it is your tires (mine also vibrated) only
Originally posted by Tajam
How noticable is this vibration?
are there any TLs that dont have the vibration problem?
I got my TL the first month they were out and Im not noticing any vibrations...
Who would figure a vibrating car was normal like they say
i checked to see if i have the vibration in SS mode....i dont...only happens in AT mode
i guess its the 1500 exhaust rattle or somethin
ive also noticed i can feel the exhaust noises at 60km/h when the car shifts to 4th or 5th at 1500rpm...
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
