Upper control arm
Old May 29, 2023 | 07:01 AM
eber_rod10's Avatar
5th Gear
Upper control arm
I recently installed some skunk2 adjustable control arms on my tl type s, the passenger has been making popping noises when i turn my steering wheel and drive slow and in reverse as well, i can feel the pop under my feet, any idea on what i did wrong?
Old May 29, 2023 | 08:05 AM
BROlando's Avatar
have you looked to see what's causing the noise?
Old May 29, 2023 | 08:28 AM
eber_rod10's Avatar
5th Gear
yes, i had thought maybe the upper control arms were sitting to low which is stressing the ball joint and or the bushings. I had adjusted it a tad bit higher and it still makes that popping noise.
Old May 29, 2023 | 09:55 PM
2.2Lude's Avatar
Start by retightening the control arm bolts. Mine were a little loose and I had the same popping noise.
If that doesn’t resolve it check the ball joints themselves. They are not of great quality. I kept a few on hand because I would go through 1 year. Really irritating but the Skunk2 arm design was much better than the competitors and didn’t knock my strut towers on the track.
Old Aug 18, 2024 | 03:16 PM
bbsitum's Avatar
Did I see some video past year where some Chinese unscrew front compliance bushing and just turn wheel and front compliance bushing jump out of housing or I just dreamed it? Can not find that video at youtube.
tmdenn
Oct 27, 2017 09:28 PM
RoadRover
25
May 29, 2016 11:20 PM
YL Al
Nov 22, 2009 11:39 AM
NauTiC*
1G CL Tires, Wheels, & Suspension
Sep 9, 2006 07:39 PM
