Unstealable license plate
Man of God.....
I had my plates stolen. I need a way to stop this from happing again. I did a search here. But nothing. Has anyone seen anything like a one way screw? I found only one product on the web. Here it is = http://www.robinfalls.com/products.html
Anyone have anything better? I need some real ideas here, not jokes about this..... OK?
Thanks in advance!!
Thanks in advance!!
Saw it on cops the other day, drug dealers and people using stolen vehicles to commit crimes swap the plates
Or, you could take the bumper off, use a longer bolt, one that would require removing the bumper to remove the plate ...
idk...
^They are called security torx.
I agree your best bet is going to be something that requires a specialized tool. I think the OP's screw would work best since it's not very common. It reminds me of the screws they use on hardware in bathroom stalls though..lol
Man of God.....
Thanks!
Now this sounds good! But can it be grabbed by say a vice grip? Thats how they got my other round head screws off. Could have been a pliers I guess.... I would like to see any other ideas! Thanks guy's. This place never let's me down.....
Man of God.....
Thanks!
OK,
It looks neater, I'll give you that. But my old round head screws were grabbed onto by a vice grip or something like that. This thing would be easier than the round headed screw! I think anyway. Don't you. I am leaning to the security torx so far..... Here is the link to Advanced Auto-http://shop.advanceautoparts.com/web...hedFrom=header
Take a look with the vice grip approach in mind.
I have the security torx on my car and I would guess if someone was determined they could get them off with vice grips. They are round headed but pretty small. It would be frustrating to get of with vice grips thats for sure.
How about these. Low profile and very hard stainless so a vice grip wouldnt be able to get a bite on it.
http://www.brycefastener.com/
Man of God.....
Yes yes and YES!!
I think this is the best I have seen so far. Now, does anyone know what size is used on the TL? If I don't see anything better I think I'll order some of these.....
Thank's!!
Thank's!!
I ordered a set of allen key stainless steel fender bolt's from .net for a 2002 Accord for around $10 or $15. I have 4 on the front and back and they are the best I could find for the price. They look similar to the Mugen plate bolt's.
Jokerman
Thanks in advance!!
Thanks in advance!!
This looks cleaner:
http://www.youtube.com/watch?v=klE0D7gHvB0
If someone could find something like our end link bolts but with very smooth rounded heads. You would start the bolt with your fingers and then go behind and stick an allen key or whatever type of design from behind through the bolt hole and screw it in from the back side. I have attached a little scetch of this to give a better idea of what i am talking about.
You could do the samething I did with the clear-corners on my Infiniti when they got stolen... Go to an electronics store, and buy magnetic reed switches. (The things that home alarms use to put on doors windows). Get the kind that is normally closed, and opens when placed in a magnetic field...
Then mount the switch behind the bumper, and glue a rare-earth magnet to the back of the plates... Then splice the switch into your hood-pin switch. I think you can splice the rears into the light for the rear trunk, unless there is a pin switch in the trunk too... Anyways, this makes it so if someone takes your plates, the alarm will go off...
Here is what the switch looks like... (You can get the kind that is inside a plastic casing, like those found on aftermarket home alarm installs, but those are more expensive, but even those I think are like $5.00. The one pictured below is the one I got... It's the size of a diode. I got it at an electronics store that sells resistors and capacitors... I think this switch was like $2.00
Man of God.....
Fearless DIY Guy
The bolt is a standard M6x25, 8.8 grade. If you're looking for the hardware specifics, this conforms to any fastener under the ISO 4017 OR DIN 933 equivalent in the 'OE' spec.
So, there's a shit-ton of 'security' grade fasteners, you just need to get one that's fitting equivalent to the above listed characteristics, and you're GOOD TO GO.
Here's a great variety, again, you're looking for an M6x25.
http://www.tannerbolt.com/products/S...FcEmtAodgGsaLg
This makes sense, but when I had my '08 Charger stolen I didn't have any type of anti-theft license plate cover.
When the cops eventually found my 'shell-of-a-car' the plate was just sitting in the back seat.
Honor among thieves?
you guys do realize that even if you put the best bolts or even welded a bolt on that the license plate can still be pulled off right?
The screws actually go into the clips! The clips can be broken with enough force!
OP like others said i would think security torx are the way to go. Most thieves dont carry security torx drivers and they prly will just move onto another car instead of hassling with yours. No matter what you use they can find a way atleast with security torx if they do they prly wont cause damage to your car.
rcs86
08-02-2016 06:52 PM
kixo
09-25-2015 03:07 PM
