TypeS headlight conversion question!!
Im doing the TypeS front end on my 06 and i found out the ballasts on an 06 WILL fit on the TypeS headlight...For my fogs i am using a 9006-h8 conversion harness ($25 from innovativewiring)..my only concern now is how to make the turn signal hookup...04-06 uses 7443 and 07-08 uses 1157...any suggestions?
I tried looking for a conversion harness but could not find anything at all. And i tried searching on this forum but the search wouldnt work for me
Looking for new mods
or u can shave the lil notchs down accordingly and make it fit properly on the socket not the mounting base of the headlight....goodluck either way....dremel witht he plastic cutting tool piece on it.
I went to advance auto today and could not find the 1157 socket with pigtail...can someone refer me to one online or a location that has it? the car is pretty much waiting on this last piece!!!!!
try asking the dealer ship for the harness? Might probably cost more than expected though...Im sure that they sell the 1157 socket seperately as well, this route will require some connectors you will have to find to connect to the pins of the socket.(I could be wrong, i dont know what the end of the 1157 socket looks like where the harness connects).
someone suggested to get #16 from here:
http://www.acuraoemparts.com/delray/...14sep4_b08.gif.
but then i dont how if that would plug directly in the 04-06 harness? Also i looked on Delray's site and there is different part #s between 07 and 08 type S's..
Being an Acha Bacha in
You can buy the sockets from www.acuraoemparts.com and you will need 06+ ballasts to make it work. Chinaman is selling a set in the BM.. PM him.
sooo... if you do this conversion what do you do with the DRL? What are they hooked up to? Or can you throw some other HIDs? Or foglights in there? I'm a headlight newb... sorry.
^ really? So I have no choice but to go with the lower fogs? I have an 06... so I havne't done any 'accord-fog-mod' or anything like that. So if I decide to just change the whole front to a Type-S front with lower fogs. I guess my current fog power supply can go to those right? Then, what do I wire the DRL's too since the 06 doesn't have them?
tman570
06-11-2019 07:56 AM
HondoGermany
23
01-08-2016 03:01 PM
