Type-S instrument cluster
Could not find any info on this..can a 07 Type-S instrument cluster ( red) fit the regular 05 TL? if not has anyone changed the light so its not blue but red..?
Former Whyner
This has been done before and IIRC correctly it was posted in Stillhere153's "Will this fit my car" thread. I thinnk I remember seeing that the TMPS was a problem and that Yellow Info icon was always lit.
It definitely fits! I have it in my 05 and it will also work in 06. The issue is it requires A TON of work to get the switches on the right hand side to fit. You have to dremel the opening and build the mounts which unless you do it perfect the first time will require a ton of touch up. I used a combination of JB Weld, dremel, sanding files, and patience to do mine. It came out so good you cannot tell it's not a factory piece. I even painted it with Duplicolor bedliner to give it the factory texture.
6spd FTW
Former Whyner
Former Whyner
BAM i found it! I asked the same question last year and this member John-Germany did it
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/cluster-acura-tl-07-fit-acura-tl-04-yes-no-747809/
Hi,
the cluster will work, but you always have the tpms info and the airbag warning light. I'll try to change the airbag module, too.
Perhaps, this light will turn off after changing the module.
Good luck
Hans
Good luck
Hans
^^^different.
DerrickW
11-15-2015 05:52 PM
