TSX Trunk Feature on TL
GÜNnµ ĦÏ
nooo. we have it better. As you notice our TL's only have one key hole on the WHOOLLEE exterior. And if you do the mod that some people did here that elimintated it, then you have no key holes at all.
Moderator Alumnus
You could remove that piece.
How you replace that lock is how you do the emergency unlocking.
http://www.acura-tl.com/forums/showt...5&page=3&pp=25
You could find this cTLgo MOD in GARAGE, too.
GÜNnµ ĦÏ
What RETS SAID!!
And don't forget, if your battery is dead and you open the door with the key, there is a manual trunk release located behind the arm rest in the rear seat, in case you need to get in the trunk.
Here is a breakdown on the door handle and the lock cylinder cover
http://www.acuraparts247.com/sunnysi...All&vinsrch=no
Shift_faster
Originally Posted by gabedabomb
fucked. Call a locksmith. Oh wait, since you modded it they won't be able to pick the lock, and jimmying it thru the window will likely scratch it.
like rets said, you can remove the piece, and use your key... takes less than 30 seconds
Originally Posted by -=¤willhaven¤=-
FOB 2
Team NightHawk VP
i have a quicky question, if ur car is locked and ur key fob has no battery, and you use the key to open the car...and the alarm goes on, how do you shut the alarm off? it happened to a 96 accord and we couldnt get the alarm off until we changed battery in the fob...it didnt shut off then we tried to start the car and it didnt start at all??
its kinda complicated but i think you guys should understand...thanks
Cliff
Cliff
Moderator Alumnus
Cliff
Cliff
If alarm is on, you could insert your key into key lock and turn it.
This should be able to do it. My 94Legend can do so.
http://www.acura-tl.com/forums/showp...8&postcount=24
TLDude876
12-28-2016 03:18 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
