TSX Steering Wheel
Originally Posted by ONAGER
Does anyone know if it's possible to replace the TL steering wheel with the '05 TSX's? I saw the price of the TSX steering wheel and it's not expensive at all. I just need to know if it will fit on the TL. The Valencia dealership said that there's no way of telling. Go figure.
Thanks.
Thanks.
the TSX's interior is just simpler I think. I might go as far as say it looks a little... cleaner. But I like the Exterior of the TL so much more. Espeically after A-Spec or another BodyKit.
The TSX is just... I dunno, I like the TL exterior much more. haha.
Shift_faster
Personally, I like the 3 spoke style of the TSX better. However, I do not like the skinny rim. I considered investigating into a swap, until I sat in a TSX, and the width of the rim bothered me.
I like my A-Spec grip better.
Registered User
it's not going be a simple swap, the cable reels are different , which means the wiring is going to be different, but most likely the steering wheel can be switched
I had a similar thread on the old TSX board several months ago, but got no response.
I was hoping to put a TL wheel in the TSX.
I am not a fan of the three spoke wheels.
the reason i love hooking up cars so much, is because ANYTHING your mind can think of can be done. so im sure that the steering wheels can be switched. but its got to be expensive. i priced the tl airbag, and the airbag alone is like 800. the outer wheel part is like almost 400. good luck
Originally Posted by bluenoise
The buttons on the TSX wheel aren't backlit like those on the TL. It's not a problem if you've memorized them, though.
rockyboy
12-06-2022 02:29 PM
