Trunk LED or Cathode Light
Old Feb 3, 2011 | 09:55 PM
IDM's Avatar
IDM
Hi can someone tell me what type of bulb the inside trunk light is? Please let me know if you would go with a led bulb or the cold cathode.
Also a link to a thread with instructions on how to change all LED bulbs on the car out would be very helpful. I've done quite a few of them but would like instructions before doing the rest to make sure I don't break anything while removing.
Thank you.
Old Feb 3, 2011 | 10:01 PM
paperboy42190's Avatar
cathodes will be brighter than LEDs but cathodes take longer to warm up. it all depends on what you are looking for. personally I prefer cathodes.
Old Feb 3, 2011 | 10:32 PM
stvtec's Avatar
'06 WDP TL 6MT
The cathodes look really great, I have them installed to illuminate my rear plate.
BUT
They take awhile to warm up and get bright. When you're going in the trunk, its probably going to be a quick in-and-out. You're not going to open the trunk and be digging around in there for 10 minutes while the lights come up. I think the CCFL might be a poor choice for illuminating the trunk. Works fine for the plate, because once they warm up they are going to stay on bright until you're done driving.
Old Feb 3, 2011 | 11:47 PM
thait's Avatar
I need a car in
um, not true. there's different types of leds. I had cathodes before and i took them out and switch to leds and i haven't seen any cathodes out brighten my license plates light before.
Old Feb 4, 2011 | 04:56 AM
i've also had both. im sure there might be some LEDs that are super high powered that emit more light than cathodes. however, dont forget that a lot of times leds LOOK bright because it comes from a concentrated spot. cathodes on the other hand, emit light evenly all around a larger area. an example is when people use LEDs for foglights. that thing gives you nearly zero visibility but looking into the led it will still appear bright due to its intensity.
Old Feb 4, 2011 | 09:21 AM
ggesq's Avatar
Did you even look in the 3G Service Department? I'll give you a hint instead of spoon feeding it. It's in section "G Lighting"!
Old Feb 4, 2011 | 09:25 AM
sixsixfour's Avatar
I use LED in mine and its more than enough:
the one Im using in the trunk is the one on the right:
Old Feb 4, 2011 | 10:23 AM
myron's Avatar
all your trunks are so clean. Mine is a freaking disaster. I can't figure out how to put in that net in the trunk. It just doesn't work for me.
Old Feb 4, 2011 | 10:47 AM
jimmyl's Avatar
Plastic schmastic
Mine isn't dirty but it is always FULL!!!!
I actually do use the side net......
I really need a rubber trunk tray/mat.
Old Feb 4, 2011 | 11:27 AM
myron's Avatar
^ yours is neatly packed. Mine is just a mess. 2 years ago I helped my boss paint his house, still got stuff in the trunk from that day. Tranny fluid bottles from 2 years ago. Random articles of clothing that are not even mine. Shoes, Steel toe boots that are not mine or anyone's that I know. Security camera, like a big one. a bunch of water bottles filled with alcohol and pop, a year old. And some tennis rackets haha I hate cleaning out my trunk so I just never look in there.
Old Feb 4, 2011 | 01:11 PM
jwr0ng626's Avatar
^ LOL damn winner.
anyone have pics of their cathode sticks installed to the ceiling of the trunk? Did u guys remove the carpet? or cut thru it
Old Feb 4, 2011 | 01:34 PM
LoveMyTL-S's Avatar
Originally Posted by jwr0ng626
^ LOL damn winner.
There's carpet on the trunk ceiling or the trunk door ceiling? Isn't it just the door that has the lining?
Old Feb 4, 2011 | 03:09 PM
DuoDSG's Avatar
Make it so
Thumbs up
That looks WONDERFUL. I'm assuming it's plug-and-play?
Either way, could you provide the model and item number for that LED unit, and install instructions (if you have them)?
Many thanks!
Old Feb 4, 2011 | 05:08 PM
sixsixfour's Avatar
Many thanks!
unfortunately it wasnt plug and play.
the connector is plug and play. its a typical 194 wedge type connector (same socket as the front door courtesy light). the actual bulb housing in the trunk is identical to the pain-in-the-ass vanity mirror light. but it pops off easily.
what i did was pop that off, connect the socket, ran the wire outside the light housing, put back the housing and then stuck the LED board ON the outer lens of the housing.
the size of the LED board is just enough to cover the trunk light housing. i used double stick tape to hold it there.
the LED board itself is generic. I got mine from a friend. its a 50/50 LED board or something like that, which is super bright. not sure where he got it from. the socket used by the connector again is a 194-type wedge socket.
Old Feb 4, 2011 | 05:10 PM
sixsixfour's Avatar
here's how mine looks. hope this helps.
Old Feb 4, 2011 | 05:19 PM
myron's Avatar
That looks great man. I will try to mess around with it one of these days. I just got my CC lights for the license plate so I'll be in the trunk this weekend and try and figure it out.
Old Feb 4, 2011 | 06:34 PM
DuoDSG's Avatar
Make it so
Thumbs up
Just to make sure I follow, the actual install doesn't require any further hookups besides the electrical connection for the existing light, right?
Although it sounds goofy to do so, putting the LED board outside of the lens cover is no big deal at all. I'm just not ambitious enough to want to run extra electrical wires throughout my car, and your solution sounded perfect either way. Did you have to cut any holes in the fabric to run the wire outside of the housing? Or did you cut into the housing itself?
Lastly, have you had any problems with anything knocking into the LED board? It sounded like you just stuck it up there and left it like that.
Sorry for all the questions, but I do appreciate your willingness to share. One love.
Old Feb 4, 2011 | 08:57 PM
thait's Avatar
I need a car in
sixsix four is running the exact same thing i have =]
there wasnt any need to cut anything or cutting the housing. the board came with 3m tape on the back. What i did was use the 168 connector pluged it in run the wire out and put back on the lens cover. after that i pulled off the tape and stuck it onto the lens cover. its been on there for a good 6 month and everyone always commented on how bright it is.
Old Feb 5, 2011 | 01:10 AM
xtcxjigga's Avatar
私を知らない
LOL, I finally learned how to put my cargo net in after seeing this pic.
Old Feb 5, 2011 | 04:23 AM
dano4o8's Avatar
I'm actually interested in how he got it to look this nice...i had mine done wrong this entire time..maybe a closer pic of? o and I used a LED plate for my trunk light. and it's more than enough to light the trunk, simple plug n play
Old Feb 5, 2011 | 04:42 AM
pnoi521's Avatar
Registered TL Owner
This is how the net is supposed to go. Took these about to a year ago to help someone else figure it out. Hope they help
Option 1 (How I always have it)
Option 2, Over the Navi Drive
Notice how this option makes a little pocket thing on the top, not sure if it would actually be usable though.
Old Feb 5, 2011 | 11:53 AM
jwr0ng626's Avatar
i'm pretty sure there is carpet on both. I was initially going to get some cathodes but ran into that... so haven't looked into it yet
Old Feb 5, 2011 | 12:56 PM
sixsixfour's Avatar
yup. exactly. the only thing electrical you have to "mess" with is plugging the connector. then you just put everything back into place, run the wire outside the light housing and tape the LED board on the cover. no modifications to the housing itself. i pop the LED board off, its back to what it was.
and Ive had mine set up this way for over three years now, nothing's ever hit it or any of the LEDs go out.
I pretty much confirm thait's response.
Old Feb 5, 2011 | 05:27 PM
DuoDSG's Avatar
Make it so
Thumbs up
Again, thank you for the info! I think I found something very similar (if not the same) as what you've both got in your trunks:
http://www.superbrightleds.com/cgi-b...cblamp_T10.htm
T10s- the connector type looks the same, but there are two different styles: the 36 and 24 LED styles, $5 difference between the two.
My brain is telling me that buying the 36 LED would give more light output, but then again the same voltage is going into it so I'm not sure that would make sense.
I don't know of any other websites that sell these (you all probably do), but I'm also curious as if there's a difference between the ones that have the LED bulbs exposed, and the ones with just the yellow sticker-type bulbs. Any thoughts?
My apologies for being clueless, I've never bought these before so I figure I might as well ask.
Old Feb 5, 2011 | 10:10 PM
myron's Avatar
trying to do my license plate lights and those 3M wire taps are terrible. They don't pierce the wire so now I have to strip the wire and use the electrical tape. Such a hassle
Old Feb 6, 2011 | 02:01 AM
stvtec's Avatar
'06 WDP TL 6MT
F that, I took some spade connectors, cut them real narrow with a Dremel, and plugged them right into the factory plug (crimped on to the CCFL wires of course).
Old Feb 6, 2011 | 12:20 PM
sixsixfour's Avatar
the ones in my trunk are exposed. no problems for me there.
if you can see if the 36LED will fit. mine is only a 24 and its just the same size as the lens housing and opening. the 36 might be too big to properly fit.
Old Feb 6, 2011 | 09:42 PM
DuoDSG's Avatar
Make it so
Thumbs up
Hmmm you bring up a good point. Are the dimensions on the one I found the same as the one you have? If not I'll have to find somewhere else online whose dimensions are closer to the size you recommend.
Again, a million thanks for your answers. Very grateful, I will definitely have this baby installed by the end of the week at this rate.
Old Feb 6, 2011 | 10:01 PM
myron's Avatar
didn't have a dremel so I just stripped the wires and electric tape wrapped them together. It works well and if i have to go back to stock, I just take the wires off and wrap it back up with electric tape. Nothing fancy but it works. And I finally got my trunk net the way it's suppose to be because of this thread haha
Old Feb 6, 2011 | 11:54 PM
sixsixfour's Avatar
ill see if i have time to take a pic of it during the day with a ruler so you can see how big it is. I think if the 36LED is slightly bigger it will have to end up partly on the actual trunk lining.
glad to help.
Old Feb 10, 2011 | 08:08 AM
IDM's Avatar
IDM
Can someone please give the proper link for the correct sized board?
Also how long does cathode really take to warm up? Im hearing mixed things here. Thank you.
Old Feb 10, 2011 | 08:12 AM
myron's Avatar
mine takes a few seconds to warm up but I am also in - 30c weather at the moment so it's expected. In the summer I don't think there should be any problems
oyayjoe
Jan 1, 2019 10:17 PM
benny_jdm
Jan 31, 2016 06:15 AM
handsom-hustla
Nov 13, 2015 05:04 PM
oyayjoe
Sep 12, 2015 04:40 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
