Trip calculator accurate??
Old Aug 10, 2012 | 01:57 AM
EvilJoker's Avatar
All Around Klown
I used my trip calculator last weekend on a little road trip and it showed a 31mpg average. I know these cars are rated for 29hwy...
Old Aug 10, 2012 | 04:34 AM
TheChamp531's Avatar
Chapter Leader (San Antonio)
Yes.
Old Aug 10, 2012 | 05:18 AM
paperboy42190's Avatar
Yes.
Old Aug 10, 2012 | 06:27 AM
AirForceFX's Avatar
Blue Skies
Wait, seriously?
Old Aug 10, 2012 | 06:46 AM
yes.
Old Aug 10, 2012 | 07:29 AM
blueracer17's Avatar
Yes, just do the math!!
Old Aug 10, 2012 | 07:32 AM
guise, he's just joking, albeit devilish.
Old Aug 10, 2012 | 07:44 AM
BeezleTL85's Avatar
Needs a 930
Take the 31 and divide it by 6. Then take the 29 and multiply it by pie then subtract the first figure you got. Divide that by .0678 and you'll get it how fast you were driving.
Old Aug 10, 2012 | 10:52 AM
TheLowLife's Avatar
1506.14552605703mph?
Old Aug 10, 2012 | 11:12 AM
EvilJoker's Avatar
All Around Klown
Old Aug 10, 2012 | 11:20 AM
Undying Dreams's Avatar
Yes
Just because it's rated for 29 doesn't mean it's going to stop right at 29. Run your A/C low and average like 65mph and you'll be close to 35 or more.
City is rated at 19 and before I switched tires I was making 24 in the city.
But only traveling 28 miles is an inaccurate reading really, you need to run further to get a more accurate MPG reading.
Old Aug 10, 2012 | 11:29 AM
BeezleTL85's Avatar
Needs a 930
Try the entire tank. I've gotten it to say ">50" . I didn't reset it until I got on the highway like .2 miles after filling up. Then I hit 100 and it went down to the high 20's
Old Aug 10, 2012 | 11:40 AM
swoosh's Avatar
takin care of Business in
you mean some like this:
in 1 tank:
Old Aug 10, 2012 | 11:58 AM
BeezleTL85's Avatar
Needs a 930
You got 475 out of your tank? That's awesome
Old Aug 10, 2012 | 12:15 PM
swoosh's Avatar
thank you....the most I have gotten is 505...i stalled couple miles from my exit
Old Aug 10, 2012 | 12:24 PM
david_vang's Avatar
Originally Posted by Undying Dreams
Yes
What tires did u use to get 24 in the city? Right now I'm averaging about 17 city.
Old Aug 10, 2012 | 12:53 PM
swoosh's Avatar
^^^ David, city MPG depends on driving habit....
easy on the throttle, coast to stops, shifting early are couple things which will yield you better city mpg....
Old Aug 10, 2012 | 12:55 PM
They were BFGoodrich G-Force, noisiest tires I've ever heard though, sounds like you're in a lifted truck. Could be because I switched wheel sizes as well though but I'm leaning towards the stickier summer tires.
Old Aug 10, 2012 | 12:58 PM
david_vang's Avatar
I'm pretty easy on the throttle and never use sport shift so it usually changes gears at around 3k. but he said his tires affected his mpg so I was wondering what type of tires were most advantageous.
Old Aug 10, 2012 | 01:03 PM
Definitely stay away from Ultra High Performance summer tires that is if you're looking for better MPG. I don't really care, still making 21-22.
Old Aug 10, 2012 | 01:05 PM
swoosh's Avatar
3K is a lot....i usually shift around 2200 rpm....
but since i got my exhaust, I shift around 3500 rpm
Old Aug 10, 2012 | 02:19 PM
lleron's Avatar
I'm going to vote no... I measure my gas after every fill up and my MID constantly says 28. However, I've not once calculated more than 26 when I calculate by hand (over at least 15 fill-ups).
Old Aug 10, 2012 | 02:32 PM
swoosh's Avatar
^^^ try resetting the trip computer....it says AVG MPG and not instant or trip MPG
Old Aug 10, 2012 | 03:01 PM
TheLowLife's Avatar
Since we are talking about it.. anyone know how far you can go once the range says 0? I've gotten it to 1 mile before getting gas.. didn't want to push my luck
Old Aug 10, 2012 | 03:17 PM
swoosh's Avatar
i tried it to find out how far I can go and hence stalled with no gas. This is what came from my "experiment"
When the light comes on you have ~3 gallons in there....so depending on the type of driving/mileage you get, you can calculate
Once the range goes to ZERO, you have ~1.25-1.5 gallons in there....
Old Aug 10, 2012 | 03:21 PM
TheLowLife's Avatar
I knew you would know
Don't you put like 5 gallons at a time or something at each stop?
Old Aug 10, 2012 | 03:23 PM
swoosh's Avatar
^^^ Yeah as a part of my diet (learned from Inaccurate) i only fill 5 gallons at a time, unless am going on a road trip....then i fill her up
Old Aug 10, 2012 | 03:39 PM
TheLowLife's Avatar
Do you get more mileage by only putting in 5 at a time?
Old Aug 10, 2012 | 03:41 PM
swoosh's Avatar
gas weighs ~6lbs per gallon
full tank = 17 gallons
i put in 5 gallons
12 gallons x 6 = 72lbs....
so am carrying 72 lbs less
Old Aug 10, 2012 | 03:46 PM
TheLowLife's Avatar
gotcha lol
Old Aug 10, 2012 | 04:42 PM
Acura_Dude's Avatar
David_Dude
From all the heat, summer tires are great.
Old Aug 10, 2012 | 04:54 PM
07NBPTL-S's Avatar
I've made it 10 miles further after my trip computer range said 0 miles, didn't want to stall though so i got some gas.
neuronbob
23
Jul 16, 2019 10:48 AM
spoiler900
Oct 10, 2015 06:48 PM
Froid
Sep 27, 2015 06:16 PM
ThermonMermon
Sep 22, 2015 03:36 PM
