Transmission "thunk"
I'm hearing a "thunk" after I back my 04 TL out of the garage and shift into D (5AT). Anyone heard this on your TL? Usually hear the "thunk" after I've gone forward just a few feet. Doesn't do it any other time. Other than this, everything else is fine with my TL.
It happens on my RSX. I don't remember what the explanation was. I believe it's normal. Something to do with the brake in the front wheels.
Originally Posted by apwalsh
ABS Self-Check?
I have to place this issue as the headline of Garage, too...
"Thump", "Clunk", "flap"... are all the same, not "click" (when hitting the brake). It usually will take place after your car sits more than a few hours. When you move forward again and reach almost 10 mph (check out this... by yourself) after starting your engine, you may hear this noise/sound once.
Normal... ABS is checking/working... except some tech discovers the new explanation for us...
Originally Posted by Road Rage
I have never heard those sounds in my car - only the doors locking at 10 MPH. My ser# is in the 50's. I have alrady changed the ATF once (at 1000 miles), so I have a 40% alternate fill, and will do the second this weekend to get closer to a full alternate fill. Using a Z-1 spec'd synoil.
I'm sure some cars are quiet without any noise. Sometimes, my car would give me "thump" even though I just turn off the engine and restart it again. Sometimes, I won't hear a thing in the morning while driving out of my garage.
Originally Posted by hokietl
Roadrage...how did you fill the ATF? From the top through the dipstick ( rather small opening) or under neath the car at the trans filler hole. I'm thinking about changing the ATF in mine also.
ABS test is all. Like a self test activation when you first drive it. Normal
Originally Posted by 92NSX
I too have noticed this sound recently. It almost sounds like a motor/trans mount is loose and the sound is it shifting forward. Sometimes you can barely hear it other times it is VERY loud. I plan on making an appointment in the near future to have it looked at along with a couple of other things. I"ll post the findings.
I don't think so. I have two other Acuras with ABS and I know the sound that those make and it's not the same.
I'm eager to know what's the result your dealer says. Please keep us updated. Thanks.
joflewbyu2
Oct 8, 2015 11:16 AM
