Transmission Fluid Change Help
Old Jul 14, 2006 | 05:09 PM
PPLAPW's Avatar
I'm in
Question Transmission Fluid Change Help
I just did the B service and apart from the oil change, I also replaced the cabin filter, thanks to this site. I also have Hawk brake pads on order.
Since the majority of the people here changed out to the GM Syncromesh tranny fluid, I decided to do the same. Now I located the bolt to drain out the fluid, but I couldn't find where to fill it! Can someone lend me a hand? Luckily I didn't begin, but I want to change it out ASAP.
Also another question, do I really need to replace the crush washers? I'm thinking I can just reuse them.
Any help is greatly appreciated! Thanks in advanced....
Old Jul 14, 2006 | 06:27 PM
subinf's Avatar
One on the right for me
keep the washers. the fill hole is on top of the tranny. really easy to see with your cai. there should be a factory check off mark on top of it. you stick a 3/8 socket in there. its a pain in the ass to break loose.
Old Jul 14, 2006 | 07:19 PM
ONEOF137's Avatar
I replaced the crush washers when I changed my trans fluid, but you can reuse them if you wish. Just lay a flat file on your workbench and then lay the crush washer on the file and with your finger and thumb slide the washer back and forth a few times to remove any possible burrs, thus making a flat surface again.
Use a 1/2" drive ratchet and extension bar(s) with a 1/2" to 3/8" adapter (it's actually a 3/8" drive, not socket that fits in the filler plug). There is less flex in the extension bar(s) using a 1/2" drive, making it easier to remove the plug. Use a 3/8" drive ratchet to tighten plug so you don't overtighten. . .
Old Jul 14, 2006 | 08:10 PM
PPLAPW's Avatar
I'm in
Thanks for the info. I have and idea what to look for...
Old Jul 14, 2006 | 10:46 PM
Ron A's Avatar
Administrator
From the fabulous 3G Garage. I didn't check them all, but the last thread has pics and scans.
C-013: DIY: 6MT tranny fluid change
https://acurazine.com/forums/ramblings-12/valentines-day-haiku-93452/
https://acurazine.com/forums/car-talk-5/omg-audi-a4-1-8t-114948/
https://acurazine.com/forums/showthread.php?t=120619
Old Jul 14, 2006 | 11:29 PM
PPLAPW's Avatar
I'm in
Wow, I should have searched. I feel like
I've been
Old Jul 15, 2006 | 02:26 AM
subinf's Avatar
^-its cool. i did a write up a while ago thinking i was the only one who posted pics. searching owned my ass as a few people had already done it.
Old Jul 15, 2006 | 09:08 AM
Ron A's Avatar
Administrator
I've been
mada51589
Jan 9, 2025 04:40 PM
cobra10363
Jul 23, 2024 04:13 PM
nanos
Nov 12, 2015 08:41 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
quake97
Aug 30, 2015 07:57 PM
