Tpms
Old Oct 16, 2020 | 07:32 AM
ROKET's Avatar
Tpms
Hello! I have a problem with the TMPS system. Constantly knocks out the error of insufficient pressure in the rear tire, although the pressure there is at the best level. I'm tired of fighting this, advise what can be done about it?
Replace sensors or disable TMPS?
Old Oct 16, 2020 | 07:46 AM
truonghthe's Avatar
replace the sensor.
Old Oct 16, 2020 | 04:09 PM
phyyr's Avatar
i had a similar problem, FL was reading at 58 and the flat tire with the ! was on the top right above the MID. after driving for maybe 3-5 minutes it would flash an error message and then TPMS would be lit up on the bottom left of the dash, if i went to tire pressure on the MID all 4 would read --. eventually the RR kicked out as well and was reading 58. i replaced both tpms sensors (in the wheel) and no more ! tire or tpms or error messages. paid maybe $50/tpms sensor from acura and honda, they looked different and technically had different part numbers but were both OEM, and the system relearned both after maybe 2-3mins of driving
Old Oct 16, 2020 | 04:25 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
replace the sensor.
+1
Old Oct 17, 2020 | 02:29 AM
mariusz439's Avatar
Try to release some air and then pump it back. Worked for me last time when I hanged the tires and one of sensors generated the error.
Acura604
Nov 3, 2022 09:17 AM
Doc Alejo
Jan 12, 2013 01:16 PM
JustinZ
Sep 9, 2009 07:45 AM
davidpham
Aug 28, 2008 09:10 PM
