TL's Horsepower
Old Jul 25, 2007 | 01:48 PM
black-TL's Avatar
7th Gear
TL's Horsepower
i currently have a 05 TL. can anyone tell me the hp on stock automatic 05 TL. when i went to motor trend, car and driver, edmunds, it all said 270 hp but i think thats not true or maybe for MT. anyways when i went to acura website, it said it had 258. i wanna know whos right..
Old Jul 25, 2007 | 01:49 PM
ggesq's Avatar
258
Old Jul 25, 2007 | 02:07 PM
ChicagoBurbs's Avatar
Truth is they are both right.
What has changed is the way HP is measured. It used to be at the flywheel, and now it's elsewhere (I forgot...somebody help). In any event, the HP has not changed, just where they are measuring it.
Old Jul 25, 2007 | 04:28 PM
fant0m_TL's Avatar
Pimpin' Ain't Easy!
+1 well said
Old Jul 25, 2007 | 04:35 PM
timmahh's Avatar
it's me, Alan Rickman.
Is it horsepower to the wheel now?
But yeah.. same power, different numbers
I think the 5AT puts less power to the ground than a 6MT..
Old Jul 25, 2007 | 04:47 PM
Texas's Avatar
The best way I can state it is that the new measurement standard levels the playing field by clearing up gray areas such as amount of oil in engine when tested, grade of gas to match owners manual, exhaust back pressure at a certain level etc... read this and you may get a better idea:
https://acurazine.com/forums/showthr...ht=measurement
Old Jul 25, 2007 | 04:48 PM
SouthernBoy's Avatar
Registered Member
Originally Posted by ggesq
258
The '04s and '05s were rated at 270 HP. I know because I have one of each.
Old Jul 25, 2007 | 06:03 PM
ggesq's Avatar
^^ true and if the way hp was measured back then applied nowadays, the stock 07 TL would still be 270 and the RL would be 300hp.
Old Jul 25, 2007 | 08:01 PM
trancemission's Avatar
Regions Leader
wow, its been a while since a HP thread came up. thanks for explaining it again guys..
Old Jul 25, 2007 | 08:50 PM
ChrisQ1980's Avatar
hates the winter
They measure it with all accessories attached to the engine. A/C, P/S, and so on.
Old Jul 25, 2007 | 09:31 PM
ndabunka's Avatar
'06 750Li Sapphire/Creme
This is actually VERY incorrect. The measurements are STILL taken at the flywheel. The only difference is the WAY they measure it. There is still loss of additional power through the transmission so the "typical" HP "at the wheels" is typically around 212. The rating system "allowed" Acura to state the HP as 270 in 2004 and 2005. In 2006 there was a new SAE rating system that mfgs would have to adopt "in the future" so that everyone would measure the same way. The ONLY thing that has changed is that EVERYONE now is "suppose" to use the EXACT SAME measurement system so that 258HP form Acura is the same as 258HP from Lexus or Benz or...
Old Jul 26, 2007 | 12:56 AM
avs007's Avatar
SAE net has always measured hp with all the accessories attached.... That happened when they moved away from SAE gross to SAE net decades ago.
The current revisions just add more clarifications. (I don't know specifically what, but that's what I hear)
Old Jul 26, 2007 | 03:01 AM
MR1's Avatar
MR1
05/5AT/Navi/ABP/Quartz
Agree but with 2006+, they have the same engine and equal output so today, either horsepower quote could be used....specifically, the rating changed, nothing else.
Confused yet?
Old Jul 26, 2007 | 03:37 AM
datmrman's Avatar
You can also refer to the thread in the 3G Garage:
A-083: SAE new horsepower rating system (posted January 17, 2006)
https://acurazine.com/forums/ramblings-12/you-know-youre-balla-when-129954/
Old Jul 26, 2007 | 04:56 AM
Registered Member
Confused yet?
Correct.
gavriil
May 21, 2026 09:02 AM
Sep 14, 2015 03:16 PM
Sep 14, 2015 10:48 AM
Aug 30, 2015 02:39 PM
