TL Type S HID's
Old Dec 14, 2013 | 07:17 AM
Weezy2328's Avatar
TL Type S HID's
hey guys I got a 08 tl type s just wondering if getting new hids would be something to consider or just keep the stock hids?? would I have to swap out the whole kit or just get new bulbs??are their any bulbs better or look better then the stock? just wondering
Old Dec 14, 2013 | 07:23 AM
nttstt444's Avatar
Why do you want new ones? Is deff not something to consiter if they are fine. The 3g has some of the best hid components money can buy from the factory.
Old Dec 14, 2013 | 07:35 AM
Nick216's Avatar
The Boss
https://www.theretrofitsource.com/
Can plug in any D2S Hid bulb. don't need the whole system. most people go with Phillips/osram. but there are cheaper band like morimoto that are reliable.
Old Dec 14, 2013 | 07:37 AM
JTS97Z28's Avatar
^^^ yup. Removing the stock bulbs for something aftermarket would typically only be a downgrade. The only bulbs that will yield better output would be the osram svs or cbi bulbs. If your looking for just more blue or purple looking bulbs you will be very disappointed. That would be equivalent of removing some OEM components and replacing them with autozone dura last brand lol. Just don't do it.
Old Dec 14, 2013 | 07:42 AM
Weezy2328's Avatar
no no I don't want something worst....something better then stock like Phillips or anythings its just a question that why im asking....are their bulbs that are better then the stock
Old Dec 14, 2013 | 07:47 AM
Weezy2328's Avatar
https://www.theretrofitsource.com/pr...ducts_id=10591
https://www.theretrofitsource.com/pr...roducts_id=257
which is better? that bmw m3 those lights look awesome which would be best? I like that purple blue color
Old Dec 14, 2013 | 07:59 AM
Nick216's Avatar
The Boss
^ you wont get that purple/blue color with any bulb, bmw has different lenses than us. the CBi is going to be pure white, svs is going to yellowish.
stock bulb=4300k
svs=4200k
CBI=5k
5k is pure white, below 5k goes into yellow. and above 5k goes into blue. only way really to get the blue color is maybe a 6k but your going to be losing brightness as you go into the non white colors.
Old Dec 14, 2013 | 08:13 AM
Weezy2328's Avatar
okay so the CBI would be better then the stock?? give a lil different look and better visiabitly
Old Dec 14, 2013 | 08:20 AM
mattpete's Avatar
I was thinking about this last night driving home in a 2013 TSX, loaner from dealer, amazing cutoff on those projectors.
My TL-S cutoff is blurry and not as sharp as I remember it, although I did a lens retro on my old TL. It drives me nuts!!! I want it like a razor, bouncing up and down… right now it's like there is a fog in my projectors.
I plan to do that on the TL-S this summer, also bulbs with 6 years of use aren't going to put out as much lumens as new ones.
So you all recommend the SVS or CBI?
I haven't bought HID bulbs in a while and when I have I've used Philips 85122+
To the OP - I agree with what everyone else says, use Philips or Osram only, most lumens and none of that garbage purple blue crap - why the hell do people think that is good or safe anyway?
Nick216's Avatar
The Boss
I have the CBI's ,they are whiter but they are like the most expensive bulb. weve got a few threads on here about them, search it up before dropping the 200$. If your brave enough to do it, look up the ZKW lens swap aswell, that will give much better cutoff lines.
Old Dec 14, 2013 | 08:21 AM
nttstt444's Avatar
Op- you saw the price tag. Personally I'd wait till the bulbs need replacing to get them, but if your going to get new bulbs just for the hell of it those would be a good choice.
Old Dec 14, 2013 | 08:24 AM
nttstt444's Avatar
I have the zkw-r lenses and that's an awesome upgrade too. Cutoff is a lot more sharp and crisp compared to stock. I'd do that before replacing perfectly good stock bulbs.
Old Dec 14, 2013 | 08:25 AM
mattpete's Avatar
No problem at all to do a lens swap, easy as baking a cake! Which I do for a living so…
I don't mind dropping 200$ on something that's worth it, I'd rather do that and get something amazing.
Old Dec 14, 2013 | 08:26 AM
Nick216's Avatar
The Boss
indeed, zkws are like what 40 bucks? I think it was nate who had pics of his CBI+ZKW headlights. Purple tint in headlight, pure white on floor.
Old Dec 14, 2013 | 08:33 AM
mattpete's Avatar
I'm really bad at searching the forums… could you help?
sounds pretty badass too.
I know i'll need a lens swap for a better cutoff but pretty sure I need new bulbs too, they just don't have the juice they should. I'm comparing to my MDX with bulbs that are a year old, with worse projectors too.
Old Dec 14, 2013 | 08:37 AM
Nick216's Avatar
The Boss
https://acurazine.com/forums/3g-tl-2004-2008-93/zkw-r-lenses-osram-cbi-5k-873155/
Old Dec 14, 2013 | 08:43 AM
nttstt444's Avatar
I think the replicas are around $40. Real zkw's cost way more.
Old Dec 14, 2013 | 09:00 AM
Weezy2328's Avatar
I don't mind spending the money for the bulbs I just wanna get the best ones out their and it looks like the cbi are lookin to be the best bet.....is it hard to replace them I don't wanna take off my bumper...definelty a different look then the stock oem ones??
anyone have pics of these bulbs in a tl? without the new lens just stock
Old Dec 14, 2013 | 09:37 AM
mattpete's Avatar
If i remember correctly you'll have to peel back the fender well to access the headlight housing to replace the bulbs.
Although I'm not positive as I had my bumper and everything pulled apart.
Old Dec 14, 2013 | 09:51 AM
GKinColo08TL's Avatar
Matt...better to search using google...like "hid bulbs acurazine"
Old Dec 14, 2013 | 09:57 AM
Nick216's Avatar
The Boss
changing through the fender wall is possible, that's what I did. BUT it was extremely hard, and I almost dropped the bulb. Also I cut the shit out of my arm when doing the driver side. Just take off the bumper, takes 5 mins.
Old Dec 14, 2013 | 10:09 AM
Weezy2328's Avatar
would you guys go with the orsam over the stock bulbs??
Old Dec 14, 2013 | 10:47 AM
nttstt444's Avatar
Nope, not if the stock ones are in good working order.
Old Dec 14, 2013 | 12:30 PM
pohljm's Avatar
absolutely not
Old Dec 14, 2013 | 12:49 PM
nate_0022's Avatar
Land of 10,000 lakes
ZKW-r clear lenses + Osram 66240 CBI and you should be set to go.
Old Dec 15, 2013 | 07:14 AM
mattpete's Avatar
I'm on it. Ordered from TRS. Is Hidplanet still kicking around? They were a huge influence when I did a retro on my Legend many years ago.
Anyway Thanks Nate!
Old Dec 15, 2013 | 11:12 AM
nate_0022's Avatar
Yeah HIDP is still active, not as active as it was a few years ago, but still fun to browse through.
TypeS860
Jan 10, 2026 11:11 AM
mvidal6
ILX
Nov 14, 2015 07:43 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
