TL Type S HID's
TL Type S HID's
hey guys I got a 08 tl type s just wondering if getting new hids would be something to consider or just keep the stock hids?? would I have to swap out the whole kit or just get new bulbs??are their any bulbs better or look better then the stock? just wondering
GKinColo08TL (12-14-2013)
https://www.theretrofitsource.com/
Can plug in any D2S Hid bulb. don't need the whole system. most people go with Phillips/osram. but there are cheaper band like morimoto that are reliable.
^^^ yup. Removing the stock bulbs for something aftermarket would typically only be a downgrade. The only bulbs that will yield better output would be the osram svs or cbi bulbs. If your looking for just more blue or purple looking bulbs you will be very disappointed. That would be equivalent of removing some OEM components and replacing them with autozone dura last brand lol. Just don't do it.
https://www.theretrofitsource.com/pr...ducts_id=10591
https://www.theretrofitsource.com/pr...roducts_id=257
which is better? that bmw m3 those lights look awesome which would be best? I like that purple blue color
^ you wont get that purple/blue color with any bulb, bmw has different lenses than us. the CBi is going to be pure white, svs is going to yellowish.
stock bulb=4300k
svs=4200k
CBI=5k
5k is pure white, below 5k goes into yellow. and above 5k goes into blue. only way really to get the blue color is maybe a 6k but your going to be losing brightness as you go into the non white colors.
stock bulb=4300k
svs=4200k
CBI=5k
I was thinking about this last night driving home in a 2013 TSX, loaner from dealer, amazing cutoff on those projectors.
My TL-S cutoff is blurry and not as sharp as I remember it, although I did a lens retro on my old TL. It drives me nuts!!! I want it like a razor, bouncing up and down… right now it's like there is a fog in my projectors.
I plan to do that on the TL-S this summer, also bulbs with 6 years of use aren't going to put out as much lumens as new ones.
So you all recommend the SVS or CBI?
I haven't bought HID bulbs in a while and when I have I've used Philips 85122+
To the OP - I agree with what everyone else says, use Philips or Osram only, most lumens and none of that garbage purple blue crap - why the hell do people think that is good or safe anyway?
I have the CBI's ,they are whiter but they are like the most expensive bulb. weve got a few threads on here about them, search it up before dropping the 200$. If your brave enough to do it, look up the ZKW lens swap aswell, that will give much better cutoff lines.
mattpete (12-14-2013)
I don't mind dropping 200$ on something that's worth it, I'd rather do that and get something amazing.
indeed, zkws are like what 40 bucks? I think it was nate who had pics of his CBI+ZKW headlights. Purple tint in headlight, pure white on floor.
sounds pretty badass too.
I know i'll need a lens swap for a better cutoff but pretty sure I need new bulbs too, they just don't have the juice they should. I'm comparing to my MDX with bulbs that are a year old, with worse projectors too.
I don't mind spending the money for the bulbs I just wanna get the best ones out their and it looks like the cbi are lookin to be the best bet.....is it hard to replace them I don't wanna take off my bumper...definelty a different look then the stock oem ones??
anyone have pics of these bulbs in a tl? without the new lens just stock
If i remember correctly you'll have to peel back the fender well to access the headlight housing to replace the bulbs.
Although I'm not positive as I had my bumper and everything pulled apart.
I'm really bad at searching the forums… could you help?
mattpete (12-15-2013)
AmplifiedDetails
09-24-2015 02:55 PM
justin.w13.walker
09-22-2015 02:21 PM
