Tl top speed
Tl top speed
Took off early for work on a long desolate road so I finally opened it up. Top speed in 5th at 6K rpm was 147. The speed appears to be drag limited, no sudden drop of in power. Since 6K is close to the Hp peak I'm sure that it would have slowed down in 6th. Furthermore, the engine shows no strain at 6K. The car pulls to 140 then it creeps to its top speed. Stability at that speed is excellent The only noise is tire related. In summary top speed is essentially the same as in my previous type S. Acceleration and power throught the whole range are much, much stronger in the 6 spd.
Wow, thanks for the post, saw it at Vtec also.
I agree that the 6spd will be better at accel, the 5AT has two overdrive gears (4th and 5th) with third at 1.029 or something, so close enough! The 6spd does not go to overdrive until 6th gear, so it will really pull! Dam that wife, first auto in 23 years!
I need to move to your neck of the woods!
Holy crap, that's one hell of a way to break a car in.
Or had you already put over 600 miles on it?
I've never taken a car over 120 or so and that was in my '97 Maxima. I'd be scared the tires would fly apart at 140+. lol! What are the TL's tires rated anyway? H?
I did 135 miles/hr back in 1990 on the just released Nissan 300Z. I will try my 04 TL later on once I break the 1000 miles range. I am doing 80 this week without a problem....
2004 TL, Nighthawk Black Pearl NoNav, 5AT
The tires are w rated 168mph. Dirac your right, the deer are murder here but we just had a special hunt this week and i'm looking forward to the regular season so I can do a dent on the population too! Not to worry rocket its over 800 now!
09-17-2015 09:01 PM
