Tire Wear?
Tire Wear?
Has anyone checked tread wear?
The reason I ask is my EL 42s show extreme tread wear, in fact I've worn out two sets of rear tires (to the wear bars) in 4,500 miles.
I'm sure this is unusual, but are others experiencing higher than usual wear - especially rear tires?
The original tires only have a treadware rating of 260, which is not very high. They are designed to give good handling at the expense of treadware.
It is very unusual for you to have extreme treadware on the rear tires of a front drive car, unless you are very aggressive, but I would think the fronts would still wear faster.
I have 5500 miles on mine with no sign of wear front or rear.
I would start investigating what could cause that with a trip to the dealer and then a tire store for another opinion.
I can already hear the dealer trying to pass it off as your driving style, and that they have had no complaints about these crappy tires.
Good Luck
Good Luck
My friend just bought a 350Z a couple weeks ago and i showed him my car. He looked at my tires and said. WOW you have 260 tread wear, and i said is that good? he said mine's 90 hahahaha
CEO, Team Anthracite
That is extremely unusual, especially since the TL is a FWD car. Have you checked the alignment or balance on your wheels/tires? Did it wear out evenly?
Powered by Guinness
It was on a trip (vacation) from Nova Scotia to Florida - 3,400 Km (2,200 miles. When I got to Florida the rears were totally worn out. Concerned I couldn't go any further without tires, I called American Acura and they suggested I take it to a dealer in Tampa to have the car checked. I called the dealer and told them my problem and booked an appointment. I arrived only to find they couldn't load the 04 alignment settings into their alignment machine, but visually inspected the rear tires and said it wasn't an alignment problem, just bad tires. Before going there, I visited a BS dealer who said just the opposite! This dealer did say that without the alignment results for my car no BS dealer would take responsibility for the tire wear.
This dealer then called another dealer in Clearwater who could do the alignment and would take me as soon as I arrived.
I got there and this dealer just wanted me to go to a BS dealer (there was some relationship) and called the dealer who, on the phone, said it was the tires and not alignment. Incredible he could determine that over the phone. The only problem was he couldn't look at them until the next day, so I asked the Acura dealer to perform the alignment, and I would see the BS dealer later. To my amazement, the Acura dealer refused to perform the alignment, and that it may not be covered under warranty. I said I'd gladly pay to have the alignment performed and asked at least three more times to perform the alignment, so I wouldn't have to go through the finger pointing spin cycle another day, but the dealer wouldn't do it.
At this point I left and called my home dealer, Atlantic Acura in Nova Scotia, and explained my situation and they stepped up and said they would reinburse me for two replacement tires.
I bought the tires and had the fronts put on the rear for the return trip. True to form, the rears were totally worn out when I got back.
Today I took it to Atlantic Acura, who said 4 new tires were ordered and they will do the alignment and install them under warranty.
On the plus side, the 04 is much more comfortable than my 99 TL was for the same trip. The seats were a real surprise for all day comfort, and it got better gas mileage (30 vs 28 for the 99).
It sounds like your dealer is a real straight shooter. I would have anticipated huge problems getting the tires replaced under warranty. Please let us know what the dealer eventually blames for the premature wear.
260 is a high number for tire wear index and tires should last a long time My 030s are 140 and I have 2000 miles on with no visible wear front or back. My Pilot Alpins have 5500 miles plus with no wear either. Something is very wrong!
I have 6500 miles on my HPT's and they have a lot of tread left. I thought they would be nearly gone by now. Mostly highway driving I guess. A couple trips to the mountains, seemed to round off the corners, but the overall tread looks good on all four.
WDP Director of R & D
Originally Posted by catsailr
There is a good article about tires in the current issue of Motor Trend by a Michelin tire engineer. According to their tests, if you only buy 2 new tires, they need to go on the rear, with the old ones on the front, even with FWD. This is just the opposite of what I always thought. In their test, the FWD spun out with the old tires on the back, but did not with the new tires on the back.
Without an alignment I was convinced the rears would wear out on my return trip (which they did) and felt a lot better about tearing up EL 42s than the new BS 750s.
I tend to agree with MT on the placement of "best tires". Since both tires were W rated and the EL 42s weren't that worn I thought it was workable, but this combination made the TL very unstable. It felt like the rear tires were steering the car.
Originally Posted by Aegir
That shouldn't happen. Those tires should last 10 times longer than that. Something is not right...
Originally Posted by Jcolbert
bluenoser: I live in Tampa. What dealer did you take it to? Ferman Acura? Also who did you talk to there?
I wasn't happy traveling to Tampa on my vacation for nothing - they really could have told me up front they could only eyeball things and weren't able to do anything.
the rears should NEVER wear out faster than the front on a FWD car PERIOD. there hast to be an alignment problem or a tire defect there for that to happen. 2ndly 260 treadwear isnt that good of a # especially for the tire not being a ultra hig performance or even close to that. the goodyear eagle f1 gsd3 is a 280, the pole position so3 is a 220 and the pilot sport is a 220 and they are among the 3 stickiest, and best tires out there, and the EL42 is in the middle of those and it cant even compare to them in performance and it only has a 260???
asahrts
09-04-2015 05:55 PM
