Tips and tricks for replacing license plate bulbs?
I removed the liner in a few mins, very simple. The problem I'm having is taking the bulbs out to replace them. I read a few threads here including this one: https://acurazine.com/forums/3g-tl-2004-2008-93/license-plate-bulb-replacement-3g-garage-g-052-a-584240/
The clips are so tight, and the space is so small that I cut my hand a few times.
Anyone have any tips or tricks?
I take my license plate off and do it from the outside, Kind of a sucks putting the light housing back in. It only goes ONE WAY, so pay attention if you do it that way.
I've been thru 3 pairs of license plate LEDs and after the first time you remove it you'll realize how easy it really is.
If you need to, try and use a flat head to pry the clip loose. You should be able to take it off by hand though.
Your supposed to put fingers on both sides and squeeze it together and pull out.
Yes, the white plastic piece on each side gets squeezed in. No - the clear triangle looking pieces are what the housing clips into. I just changed mine a couple days ago and I used a small flat-blade screwdriver to push one side in and that gave me enough wiggle to slowly work the other side free. Take your time.
I gave up, put everything back together and called it a day.
I spent another 45 mins or so - got the "clip" side of the clear clip out, but couldn't get the "latch" side free. I tried pushing from inside the trunk, pulling from outside the trunk, and it would not come out. I used a lot of force, and didnt want to force it anymore cause I didnt want to break a clip. I managed to cut my finger a few more times, so I said F it.
Maybe if someone is local they can help me one day. Pizza or beer my treat.
Damn really? I do license plate light installs all the time and never once had a problem. Just need to push the clips at the right angle and it's really easy. If you were in SoCal I'd help you out
I think trying to remove the trunk light is a lot more difficult than changing the license plate lights. There's really no reason for it to be so difficult. Just push both side clips inwards towards each other and than push the whole thing forward.
Or if you can't do that than just simply start with 1 side. Use a flat head and press it in and than push it forward to pop that side out. Repeat for the other side if necessary.
By the way I recommend disconnecting the connection that plugs into the license plate lights before you do anything. It might give you more room to see or work.
justin7779
Dec 25, 2015 10:33 PM
darksky
Sep 5, 2015 03:11 AM
Mugen TSX
Eastern Canada
Sep 1, 2015 11:05 PM
