Timing belt replacement... not lining up correctly?
Old Mar 30, 2011 | 12:59 AM
tamadrumr88's Avatar
2011 CR-Z EX 6spd Navi
Let me preface this post by first saying I've done several D-series Civic timing belt and water pump replacements. This is my first J-Series, but it shouldn't be much harder than what I'm used to. I'm using this DIY here -- https://acurazine.com/forums/3g-tl-2004-2008-93/122-diy-105k-service-timing-belt-water-pump-spark-plugs-thermostat-%2Apics%2A-784622/
With that said, I went to line up the timing belt and it looks like the rear cam has rotated clockwise about 20-30 degrees when the front cam and crankshaft pulley are at Cyl 1 TDC. If I try to rotate the rear cam more than a few degrees in either direction, it's obviously met with resistance. I'm looking at the timing marks correctly, so I think, but there's no way the cam should've been able to rotate that much!
I can't figure out how the rear cam even rotated, I just need to figure out what's wrong and why it's not lining up. Any help would would EXTREMELY appreciated at this point
Old Mar 30, 2011 | 01:11 AM
AMUA6's Avatar
ScoobyZINE
Which timing marks are you going by, surely not the covers at this point. I remember the rear being off a little but definitely not 20 or 30 degrees. Sounds like you're not TDC Where was the cam when you pulled the belt? Maybe you bumped the crank removing or replacing something?
Old Mar 30, 2011 | 01:22 AM
Pic #1 is the front cam, pic #2 is the crankshaft pulley, #3 is the rear cam (which seems to have rotated wayyyy too far)
Old Mar 30, 2011 | 01:25 AM
Bearcat94's Avatar
AZ Community Team
Did you notice if all was OK before you began disassembly?
Old Mar 30, 2011 | 03:18 AM
paperboy42190's Avatar
this is why i would not attempt a timing belt change myself :/
Old Mar 30, 2011 | 04:31 AM
SodaLuvr's Avatar
The camshaft must have spun when you had the timing belt off. I guess your only option at this point is to remove the valve covers and see if you can figure out what the status of that rear cam is.
Hopefully someone more experienced will chime in.
Old Mar 30, 2011 | 04:55 AM
TLDude876's Avatar
Chapter Leader (Houston)
Has that same issue a few weeks. You can pull it back into place with a ratchet and hold the pressure so it doesn't spring back to where it was. Yes there will be a lot of resistance but that's how I did it. It would be ideal if you had someone working you so either of you could hold the cam in position while the other put the belt on.
Old Mar 30, 2011 | 08:10 AM
VQPower37's Avatar
x2 ... too scared to mess anything up
Old Mar 30, 2011 | 08:38 AM
johnny3's Avatar
The rear cam sometimes wants to "break over center" right near the line up marks because of cam lobe position & valve spring pressure.
Do what TLDude says in the above post. Rotate the camwheel back with a long ratchet & socket & hold it there while putting the belt on.
I have a couple of little spring clamps I put on the rear cam wheel & belt when I have it where it needs to be. Be sure & loosen up the smooth guide pulley in the center of the "V", gives you some extra slack to work with. Be sure & crank or rotate the engine through several times & make sure everything still lines up.
Old Mar 30, 2011 | 10:45 AM
Looks like everything is lined up correctly now. I used a 17mm wrench to turn the rear cam counter-clockwise as I slipped the belt on. Thanks for the suggestion.
I actually didn't think the cam would spin that far without the valves hitting one of the piston. I also didn't think it'd be able to turn the cam counter-clockwise without loosening the cam gear bolt... but it took all of five mins to get everything lined up again. Must've just been the pressure from the valvetrain
I wouldn't hesitate to do it again, knowing now that it was a much easier fix than I anticipated
Old Mar 30, 2011 | 10:57 AM
TLDude876's Avatar
Glad to know it worked for you. I was a bit hesitant to turn the cam when I had the issue but it turned out fine. According to my buddy, his car now has 30 hp extra
Old Mar 30, 2011 | 10:58 AM
nfnsquared's Avatar
Originally Posted by tamadrumr88
Let me preface this post by first saying I've done several D-series Civic timing belt and water pump replacements. This is my first J-Series, but it shouldn't be much harder than what I'm used to. I'm using this DIY here -- https://acurazine.com/forums/showthread.php?t=784622
OP, you should've read through the entire DIY thread. I covered this in post #200. Yeah, the rear cam has a tendency to flip either side of TDC. Easily fixed as you saw. Glad all is well.
Old Mar 30, 2011 | 12:27 PM
I thank you for your input but if it's that important the first few posts should be edited to included that. I think that's a bit unrealistic to expect someone to read up to post #200 when the majority of pertinent info is included in the first few posts
Old Dec 17, 2012 | 10:46 PM
carlossantan90's Avatar
3rd Gear
hi, here I am, I have done my Timing belt past weekend and I didn't have seen this DIY. Everything went great except one think that I want to ask to you.
This was the first timing belt job on this car so the timing before was the factory setting. I first put the front camshaft to #1 TDC and lign up mark and then look at the back camshafts. I've notice the marks on the TB covers and cams where not PERFECTLY align ( about 5-10 degree clockwise the TB covers marks maybe... hard to know exactly but the maximum it would be off is by one theeth... I will try to take picture ). So i continue the job and remove everything and I remove the old timing. I was aware that the camshafts can slip off but nothing move.
I put the new timing belt and I didn't move the rear cams to align marks on the blocks because everything was great before and this was the from the factory like this. The auto-tensioner is OK so i don't think the I lost tension in past so the cam jump one theeth. I start the car with the new belt and everything start great good Idle. Vtec works too but I don't know if I'm paranoiyak or I may have lost a "little" of power. That's really annoying me.
I need your advice. Should I restart the job and put the back cams to marks or it's a common issue to this car to be a little bit off the marks. Will I gain HP if move it. Is it possible to see a so little loss of power if I am one theeth off or the car would ran like shit. I know and I am 99.9 % sure nothing move and I put the belt corectly with the tension on the side of the tensionner.
I can't stop thinking at this. Need your advice quickly please. I now run the car for the past three days and no issue at all but this is annoying me.
Old Dec 18, 2012 | 12:44 AM
nfnsquared's Avatar
^^^The marks might be off very slightly, usually on the rear cam sprocket. Look at the pictures in step 12 (rear cam is the right picture. Notice how the marks are off very slightly?):
But if the engine is running normally, everything is probably set properly...
Old Dec 18, 2012 | 07:27 AM
johnny3's Avatar
You can remove the 2 upper cam gear covers & rotate the c/s pulley to its tdc mark to look, don't have to remove c/s pulley & lower cover yet.
Old Dec 18, 2012 | 10:20 AM
3rd Gear
Thanks guy I will try to look at that. I will give you input if something wrong.
Old Dec 18, 2012 | 11:13 AM
ez12a's Avatar
the overexplainer
a tip you might want to try next time is marking the belt to the tooth with a white pencil or painter's tape (you would remove this after ensuring everything is lined up).
It helped me ensure that all of my timing marks were lined up properly and took out any doubt of putting the belt on and skipping a tooth.
ditto, if your car is running ok i'm sure you have it in the right position. You would lose compression if you were a tooth off and the car would sound strange.
like so:
I guess you could actually use my picture to check your belt. Just count the teeth. Note the 3 marks for the crank pulley are in between teeth.
Old Dec 18, 2012 | 01:48 PM
3rd Gear
Thanks everyone! I take a look at my car this morning and everything is line up now. I don't know why but im sure the rear was a little off but now it is on the marks. Nice idea for counting the tooth ! Didn't think to that
Old Aug 26, 2023 | 04:52 AM
cassmoney01's Avatar
I
I just did mine yesterday and before I took the belt off I notice mine was off too by the exact same as the pic below. I rotated the engine twice to tdc and still the same. I didn’t start the car cause I had some thing to still replace but I’ll let you know how it went
notfast
1/2G MDX (2001-2013)
Mar 28, 2023 08:10 AM
vaughanml2
Nov 1, 2021 10:16 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
merc009
Sep 14, 2015 06:43 PM
asahrts
Sep 4, 2015 05:55 PM
