To those with 07-08 5AT TL's...
RWD convert
I have a favor to ask. Next time you're on the highway, select sport shift mode and put it in 3rd at about 60-70 mph. Then floor the gas and watch rpm as it passes the 5000-6000 rpm range. I notice that when i do this the needle seems to pause for a split second when it hits 5000 and then again when it hits 5500 rpm(at 5500 it even sometimes looks like the needle goes back for a split second and then proceeds to go up as normal). This doesnt happen in auto mode, just ss. It also doesn't feel like the car is hesitating, it seems like it's just the needle. If anyone can help me out, I'd greatly appreciate it.
Okay.
3rd gear.
60-70 mph.
5000-6000 rpm.
Needle supposedly pauses at 5000 and 5500.
I'll prolly be on the highway tonight.
I'll try to remember to check.
3rd gear.
60-70 mph.
5000-6000 rpm.
I looked. I didn't really notice any abnormalities.
The only abnormality I noticed was...
Well, clear open interstate road, no cars at all...
I took it up to 130.
It didn't want to budge past 130, and I think it still had power to go.
Speed limited for 130? My 4 Cyl Accord did 130 lol.
I have car ADD
RWD convert
Originally Posted by Be-in my TL
Are you sure it's not the Vtec kicking in at that RPM? I know ours is supposed to kick in the 3 thousands, but maybe your Vtec is lagging.
Originally Posted by BLACKURA_NY
limiter should be around 146-147
can anyone with a definate answer speak up.
D
Mine doesn't do it, dropped it to 3rd gear, took it from 60mph to 80 (5000rpm) and then to just around 90 (5700 ish)
Didn't notice anything. Tried a few times.
No idea what top speed is, round bay area there aren't too many roads to try it on an still keep a license :-)
Note this is a '08 TL-S 5AT
RWD convert
I'm thinking it might just be my tachometer. Because in park if i tap the gas, i can hear a faint clicking noise from the tach as it climbs. Like the motor in the tach is grinding slightly or something. It's weird how the needle issue only happens in ss mode and not auto though.
AZ Community Team
Received 7,770 Likes
Originally Posted by don5504
wait so the 07 5at type-s cars can do like 146-147? Its not limited to like 130-135mph?
D
D
147 Electronically Limited: http://www.roadandtrack.com/assets/d...d/02073car.pdf
Here's a thread with a couple of Autobahn runs up to the cut off:
https://acurazine.com/forums/showthread.php?t=155112
Originally Posted by stillhere153
I have had my tl-s up to 135... so it is definitely noy 130...
as for the rpm problem... no problems here
D
vpasla1
09-17-2016 07:24 PM
mrkingstonvi
02-22-2016 01:53 PM
benny_jdm
01-31-2016 06:15 AM
IIDXholic
10-08-2015 07:53 AM
