Are these Philips bulbs Legit?
you can get Kaixen brand from our vendor Excelerate for less than that
4300k was stock
many go to 5000k for more blue that picks up the reflecto paint in lines and roadsigns
4300k was stock
you need phillips 85122+'s go to www.theretrofitsource.com to get them....
you need phillips 85122+'s go to www.theretrofitsource.com to get them....![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
actually you lose white with 6000- I have them and know there is less white light on the road surface in front of the car, but I can see lines and other things the 4300 dont pick up
4300 or 5000 are excellent choices
Next step down is 3000 and thats too yellow and its used for fog lights
the color is going to be the same regardless of maker- the number indicates the color on the Kelvin scale, with 6500 being compared to midday sun
Its about the eyes ability to seperate objects in contrast
Are they offering any warranty?- the price at 120? a pair is in the reasonable range
and I remind you that many ziners are happy with the Kaixens- they are the international lighting research facility and the bulbs come from the manufactuing dept
They make and test a lot of bulbs~
how is the sellers feedback- what do they say about returns if DOA or 1 year?
look in the gen2 threads- lots of guys with them and plenty of pics- do a search
About 2 years on my kaixens and the lights on are most of the time for safety
Life is supposed to be 3000 hours- the stock ones 2500, and both will lose color and brightness with age- its normal
The few lumens differance is not something your eyes will detect between brands ands color
phillips is a well known brand used in many OE applications, maybe even some acuras or honda
ask each seller what warranty there is
Bulb life can be dramatically reduced by touching the glass bulb with your bare fingers- oil creates a hot spot that burns into the glass causing failure
Wear latex or rubber gloves when handling bulb
you can go to Lowes, in the florescent tube section there are big pics of different light colors from 3000 to 6500
All taken of the same room so you can check the differance in kelvin
switch color? do you mean ~burns in~ with about 50 hours to its normal color and brightness-
than at lifes end it will do the pink or purple thing when you turn them on?
yes they do that like all HID bulbs do- they age and get weaker and change color at the end
Supposed to last 3000 hours of use
ripit
09-26-2015 06:19 PM
AcuraKidd
09-25-2015 11:18 PM
