Switching gear position sensor on Acura TL 07 Base
Old 09-19-2018, 10:44 PM
3rd Gear
TONETONETONY's Avatar
I’m getting the symptoms of a bad Gear Position Sensor. (Flashing D, check engine light)
havent seen to many threads on 07-08 TL
Question I have is when replacing the sensor should the car be placed in P or N?
read many forums where your suppose to place car in N prior since the part is in Neturel when purchased. but I jus wanted to make sure I do it right.
if anyone replaced recently or just in general please help. Gotta replace sensor before road trip.
Thank you
Old 09-19-2018, 11:55 PM
vpasla1's Avatar
If everything is telling you to put it in neutral without any conflicting information, then I think it's safe to put it in neutral. I would hope you would block off your tires first though.
Secondly, I would get the code read on the engine light, and also see if you can read the transmission code before throwing parts at it.
Old 09-19-2018, 11:59 PM
3rd Gear
thank you bro!
But im getting P1717 which is the sensor, and what do you mean when you say “block off tires”
i know I have to remove front tire prior to getting to the sensor.
Thank you
Old 09-20-2018, 05:35 AM
vpasla1's Avatar
Block off the tires, as in support the vehicle to ensure it doesn't roll at all while you have it lifted. Unless you're putting it on a hoist. In addition to blocking off the tires, using the handbrake will help as well to ensure it stays put.
Old 09-20-2018, 01:30 PM
Received 8,691 Likes on 6,705 Posts
Looks like you found your answer here: https://acurazine.com/forums/third-g...type-s-927946/
Jose Aguilar
11-11-2016 12:42 PM
Tl4eva
01-26-2015 01:10 PM
guitarplayer16
11-26-2011 06:37 PM
bigboifonts
09-20-2003 12:45 PM
Quick Reply: Switching gear position sensor on Acura TL 07 Base
