Suggestions needed--is these normal
Old Jun 13, 2005 | 05:22 PM
gainful's Avatar
My 05 TL has a big shock when shifting to reverse gear. It also has the jerky-shocky feel when shifting gears from 1-2, 2-3 at low RPMs.
Guys, please let me know if this is normal. I had an 03, which is very smooth, and I can't feel anything when shifting to reverse, or during tranny auto shifting.
Are these symptons all because of bad tranny mount? or there could be something else? I also have the famous 1500RPM vibration.
Thanks.....
Old Jun 13, 2005 | 06:21 PM
TerminaderTL's Avatar
Team Anthracite Member
See a dealer - this doesn't sound normal.
Old Jun 13, 2005 | 07:17 PM
scrb09's Avatar
Thanks.....
How many miles do you have ? My 04 TL had a thudding sound when put into reverse and also a slight jerk from 1-2 and 2-3 (Exactly what you are mentioning) but this was in the first 1000 ~ 1500 miles... this used to bug the hell out of me...but I took it to the dealer and he said its normal in the break-in period and made me test drive 2 other TL's and they were similar...but this sound went away, I now have 14K and my tranny is a LOT smoother then before...
the only explanation I have is that some trannys can be rough in the beginning. I would still recommend you to take it to the dealer and get it checked out.
Old Jun 13, 2005 | 07:42 PM
caball88's Avatar
ohh no is it the AT tranny problems from the 2nd gen??? hehehe j/k there hasn't really been any reported problems for the 3rd gen so it should be something different. take it into the dealer and have them look at it.
Old Jun 13, 2005 | 09:23 PM
locotl's Avatar
I have the same problems especially when shifting from 1st to 2nd (on first drive of the morning mostly).
Old Jun 14, 2005 | 09:57 AM
1995hoo's Avatar
Keep Right Except to Pass
"Is these normal" doesn't sound normal either
Old Jun 22, 2005 | 03:01 PM
kban's Avatar
6th Gear
I also have this problem. Does anyone know what causes this problem??
Old Jun 22, 2005 | 03:21 PM
Oswald Vater's Avatar
I can't say for sure what causes this problem. Mine does the same thing but only through the first couple of shift cycles then its fine. If I had to venture a guess I would say it is fluid related. Perhaps it takes a cycle or two to warm the fluid up to an effective operating temperature. In any event, I'm only going to worry about it if it becomes significantly worse.
Old Jun 22, 2005 | 08:24 PM
A_UFO's Avatar
I noticed in my TL 05 Navi with about 700 miles on the car that if I reduce speed just as the transmission is getting ready to change gears, I get a hard shift.
If I maintain or continue to accelerate (not hard acceleration; flooring the pedal) that the transmission shifts smoothly.
Just my observation so far.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
rockyboy
Oct 2, 2015 10:45 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
