STI vs. LIP on '04 base
Old 05-13-2014, 03:49 PM
abpmerg's Avatar
I searched around and saw that the idea was entertained, but dont know if anyone has actually done it. Does anyone know if the sti v lip will bolt right up to the base lip? Or Aspec?
Old 05-18-2014, 11:10 AM
Boogsephine's Avatar
I've seen a few members put it on the Type S ASPEC kit but I don't think I've seen anyone bolt it on the base kit. I'd like to know the procedure of putting it on the kit for when I install it on my car.
Old 05-18-2014, 01:51 PM
Fearless DIY Guy
DeathMetal's Avatar
The diffuser is an add-on for the Type S front underbody spoiler. There is no "Type S A-Spec"; we have two different OE underbody kits available, A-Spec OR Type-S.
The STI V-Lip diffuser is not plug and play on the TL.
Old 05-24-2014, 07:53 PM
mig0s's Avatar
here's my base TL with the sti lip and no other lip. bolts right up, needs to be stretched a little
The following 2 users liked this post by mig0s:
abpmerg (06-05-2014), Nmm555 (05-25-2014)
Old 05-24-2014, 08:32 PM
08 TL
i_TL's Avatar
Looks nice bro, What year STI? ...do you have a link? ...I wonder if it fits an 08 base?....
Old 05-24-2014, 11:23 PM
Jriddle8's Avatar
How hard are those sti lips to install? How long did it take?
Old 06-05-2014, 03:38 PM
jkos101's Avatar
im interested as well of the procedure with the base model. can it wrap around fully with some heating etc?
Old 06-05-2014, 05:22 PM
Speeden6's Avatar
I have a 06 TL base with Aspec Kit. put the 2006 - 2007 STI lip on, it is NOT bolt right up. some of the tabs match but you cant rely on them all. you do have to some screws into the Aspec lip. nothing nasty, looks clean still..... I Installed mine with the help of my 2 year old son in about 15 min tops.
The following 3 users liked this post by Speeden6:
EvilVirus (06-06-2014), Jriddle8 (06-05-2014), rockyfeller (06-07-2014)
Old 06-05-2014, 06:25 PM
Slot Machine Lubricator
1black_seven's Avatar
I like them both but, how does this look different from the home depot lip
Old 06-05-2014, 06:31 PM
Speeden6's Avatar
The home depot lip I have done and seen on other cars is not as firm and strong. same look, better material. Basically the old verbiage you get what you pay for.
Old 06-06-2014, 10:34 AM
abpmerg's Avatar
What exact lip is that? and how do you go about stretching it?
Old 06-06-2014, 10:53 AM
usdmJON's Avatar
Heating will not change the shape. It is polyurethane already set. You can bolt on side of the lip to the car then pull the other side a couple inches and bolt it up. The bumper and lip will be held together under pressure and if a couple bolts come loose you will have a heck of a time stretching it back as the lip will return to its normal position.
They look totally different to people with an eye for detail. The home depot lip looks cheap regardless that is IS cheap. The STI lip is still cheap at only 50-100 tops and looks 100x better as it is a real front lip and not a garage door weather stripping add on.
I can tell the difference in a heart beat. Check it out...
EZ Lip looking ugly. It double sided tapes to your bumper so it follows the lines of your bumper. Making it painfully obvious it is not a front lip and just a piece of weather stripping TAPPED to the front bumper. Gross.
Now the STI lip looks like a real lip. It will actually function as a front lip and increase air flow over the top verse bottom. The EZ lip is thin rubber and literally bends in the wind while your drive.
Old 06-06-2014, 11:05 AM
usdmJON's Avatar
And speaking of STI lips... here is mine on my ILX followed by the link I used as reference for my install.
You can see there is A LOT more to this lip than the ez lip. It actually jets out from the car verse hanging under it.
As for protecting the bumper. There was one ILXer that caught a curb with his EZ lip... scratched the bottom of the bumper and tore the EZ lip off... If you go up an incline the EZ lip is literally pushed under the car or torn off.
Here...
On a crazy incline... Im not that low.. you can see my bumper isnt even touching the ground. The lip is. An EZ lip would be tore off by this. No joke.
And here is the link I used for reference. Pretty easy. I did it alone.
http://forums.clubrsx.com/showthread.php?t=779120
mrkingstonvi (06-06-2014)
Old 06-07-2014, 11:57 AM
King of NYC
rockyfeller's Avatar
Is it just me or does the one on Speeden's car look narrower than the one on the other cars? Are these lips all the same exact type or did you all buy ones from different companies?
Old 06-07-2014, 01:31 PM
The Boss
Nick216's Avatar
Prolly because the aspec lip. ^
rockyfeller (06-16-2014)
Old 06-07-2014, 01:40 PM
usdmJON's Avatar
The aspec may make it look smaller as stated.
Also you can pull the lip slightly to make it look a little wider.
One Ilx owner preferred the sides of the lip to stick out about an inch on both sides. I opted to make it exactly the same width as my front bumper... which then ended up being slightly narrower than my oem lip.
There are many many sellers with this poly 06 sti lip.
Since you will be cutting it up I suggest spending around $50-80 on ebay.
Old 06-07-2014, 04:01 PM
Speeden6's Avatar
yeah if you know lips and cars you can totally tell the diff with Home Depot and actual.
The Aspec makes it look narrower, and I didnt do any cuts or stretching. some like it coming out the sides a little, I opted for it to come flush on the sides. 69.99 On Ebay delivered in 1 day (west Coast). not a bad deal and I like it. also makes your car look a little lower with the aspec and everything.
Old 06-07-2014, 05:05 PM
usdmJON's Avatar
Agreed. Just look how low my ilx looks in the front.
I too tried to make the sti lip and oem lip look flush as possible.
I've been wanting to redo mine cf wrapped.
Old 06-13-2014, 10:10 PM
abpmerg's Avatar
going to try to bolt up a lip off my buddies e92 3 series tomorrow, looks to be a good fit and will report back with results
Old 06-14-2014, 04:01 PM
KCCO
MarcoNorthPolo's Avatar
Interested in how that works out.
Old 06-15-2014, 07:37 PM
Speeden6's Avatar
Its Tomorrow...... where are the pics?
Old 06-15-2014, 10:59 PM
abpmerg's Avatar
Some stuff came up and i got busy. Hopefully ill be able to do it tomorrow after my interview. wish me luck
Old 06-17-2014, 08:43 PM
Joneill44's Avatar
Received 3,594 Likes on 1,720 Posts
Pictures!!
Old 06-21-2014, 09:41 AM
abpmerg's Avatar
Okay so i removed the center air dam plastic to get this lip to fit but im still trying to get some other pieces out of the way. Need to figure out what some of these plastic pieces are hanging down and how to remove them
Old 06-29-2014, 01:12 PM
abpmerg's Avatar
3 series lip didnt work out.
Any other members with the sti lip on the base bumper wanna give me some tips or pics of where you bolted the lip to the bumper? I cant quite figure out the best placement
Old 06-29-2014, 10:26 PM
Speeden6's Avatar
doesnt bolt up, I used some friendly black 1 and a 1/2 inch screws, black anodized to prevent rust.
abpmerg (06-29-2014)
Old 06-29-2014, 11:03 PM
6th Gear
DinishK's Avatar
Damn looks sexy
Old 06-29-2014, 11:39 PM
chrisd421's Avatar
bumper
what bumper is this? hell at the risk of sounding like a noob what car is that? it has a honda badge but I thought there wasnt a honda version of the tl.
Old 06-30-2014, 12:43 AM
huystAr's Avatar
^ tsx
Old 06-30-2014, 01:22 AM
jkopuffs's Avatar
LOL. Im done with A-Zine today
The following 2 users liked this post by jkopuffs:
CLtotheTL32 (06-30-2014), Undying Dreams (06-30-2014)
Old 06-30-2014, 07:39 AM
CLtotheTL32's Avatar
Received 9,495 Likes on 6,167 Posts
Old 11-12-2014, 09:49 AM
beastUA6's Avatar
Is it me or does the lip in this pic look like is doesn't quite make it to the wheel well part of the bumper? Like it doesn't quite wrap all the way around the bumper? I'm interested in doing this mod. Would make a great addition to my car. Just wanna make sure it'll work before spending the money. Oh and I don't have an oem lip on mine.
Old 11-12-2014, 05:23 PM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
Post more, clearer pics of this, please!
Old 11-14-2014, 11:08 AM
beastUA6's Avatar
Bump...anyone have a better pic of this on a base TL? plz post if you do....thanks
Old 11-14-2014, 11:18 AM
Chapter Leader (San Antonio)
TheChamp531's Avatar
Just don't do it. It looks fugly.
Old 11-14-2014, 01:49 PM
TacoBello's Avatar
I hate to say it, but it does look kind of ugly. Especially on the base with the oem lip on it already, like above. Looks like there are gaps where the oem lip juts in on both sides, and even if they were done perfectly spaced on both sides, it would still look silly. Two lips is over kill.
Old 11-14-2014, 04:10 PM
beastUA6's Avatar
^agreed. Whelp, scrap that idea
Old 11-14-2014, 05:09 PM
usdmJON's Avatar
Two lips aren't overkill when one is an OEM kit and the second is a splitter.
That splitter simply doesnt fit correctly with the OEM kit. A correct size splitter looks good on almost any car.
Any splitter should fit similar to this in order to look correct. Here the STI splitter, the one being talked about here, sits about an inch wider than the bumper.
So of course it will look bad on a car that is wider than that.
The splitter under that, by aeroflow dynamics, sits even wider, how a splitter should sit.
I can guarantee if the splitter fit the TL like it did this suby, it would look great.
Try doing what one TL owner did and buy 2 lips at 50 a pop and cut them at like a 60/40 and 40/60 ratio then connect the two 60% pieces to make a wider splitter.
Or contact aeroflow and have them machine you an aluminum splitter that fits for like $300.
EL BAN (11-15-2014)
Old 11-29-2016, 06:48 PM
Mfergie's Avatar
I just did the '06 '07 cs2 splitter on my base today and I think it turned out quite nice! may still do some adjusting but Im pretty happy with it
Old 12-14-2016, 01:30 AM
broke but trying's Avatar
smh
Quick Reply: STI vs. LIP on '04 base
