STI vs. LIP on '04 base
I searched around and saw that the idea was entertained, but dont know if anyone has actually done it. Does anyone know if the sti v lip will bolt right up to the base lip? Or Aspec?
I've seen a few members put it on the Type S ASPEC kit but I don't think I've seen anyone bolt it on the base kit. I'd like to know the procedure of putting it on the kit for when I install it on my car.
Fearless DIY Guy
The diffuser is an add-on for the Type S front underbody spoiler. There is no "Type S A-Spec"; we have two different OE underbody kits available, A-Spec OR Type-S.
The STI V-Lip diffuser is not plug and play on the TL.
I have a 06 TL base with Aspec Kit. put the 2006 - 2007 STI lip on, it is NOT bolt right up. some of the tabs match but you cant rely on them all. you do have to some screws into the Aspec lip. nothing nasty, looks clean still..... I Installed mine with the help of my 2 year old son in about 15 min tops.
![Name: 10418860_10152235190862955_3128887690539651703_n_zps74244b27.jpg
Size: 194.6 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/47360d1501280387-sti-vs-lip-04-base-10418860_10152235190862955_3128887690539651703_n_zps74244b27.jpg)
![Name: 983695_10152235190927955_4650340066771423615_n_zpsb70c5baf.jpg
Size: 147.5 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/47361d1501280387-sti-vs-lip-04-base-983695_10152235190927955_4650340066771423615_n_zpsb70c5baf.jpg)
![Name: 10409422_10152235190887955_5882456664273450349_n_zps9ff9c7f4.jpg
Size: 148.6 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/47362d1501280387-sti-vs-lip-04-base-10409422_10152235190887955_5882456664273450349_n_zps9ff9c7f4.jpg)
The following 3 users liked this post by Speeden6:
EZ Lip looking ugly. It double sided tapes to your bumper so it follows the lines of your bumper. Making it painfully obvious it is not a front lip and just a piece of weather stripping TAPPED to the front bumper. Gross.
![](http://i120.photobucket.com/albums/o162/DerrickA4/TSX/IMG_6912.jpg)
Now the STI lip looks like a real lip. It will actually function as a front lip and increase air flow over the top verse bottom. The EZ lip is thin rubber and literally bends in the wind while your drive.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
And speaking of STI lips... here is mine on my ILX followed by the link I used as reference for my install.
You can see there is A LOT more to this lip than the ez lip. It actually jets out from the car verse hanging under it.
![](https://farm8.staticflickr.com/7112/14036618545_0b4cfbb377_c.jpg)
As for protecting the bumper. There was one ILXer that caught a curb with his EZ lip... scratched the bottom of the bumper and tore the EZ lip off... If you go up an incline the EZ lip is literally pushed under the car or torn off.
Here...
![](https://farm4.staticflickr.com/3720/14093924800_bdf09bddec_b.jpg)
On a crazy incline... Im not that low.. you can see my bumper isnt even touching the ground. The lip is. An EZ lip would be tore off by this. No joke.
And here is the link I used for reference. Pretty easy. I did it alone.
http://forums.clubrsx.com/showthread.php?t=779120
Here...
mrkingstonvi (06-06-2014)
rockyfeller (06-16-2014)
The aspec may make it look smaller as stated.
Also you can pull the lip slightly to make it look a little wider.
One Ilx owner preferred the sides of the lip to stick out about an inch on both sides. I opted to make it exactly the same width as my front bumper... which then ended up being slightly narrower than my oem lip.
There are many many sellers with this poly 06 sti lip.
Since you will be cutting it up I suggest spending around $50-80 on ebay.
yeah if you know lips and cars you can totally tell the diff with Home Depot and actual.
The Aspec makes it look narrower, and I didnt do any cuts or stretching. some like it coming out the sides a little, I opted for it to come flush on the sides. 69.99 On Ebay delivered in 1 day (west Coast). not a bad deal and I like it. also makes your car look a little lower with the aspec and everything.
Agreed. Just look how low my ilx looks in the front.
I too tried to make the sti lip and oem lip look flush as possible.
I've been wanting to redo mine cf wrapped.
KCCO
Pictures!!
![Tantrum](https://acurazine.com/forums/images/smilies/tantrum.gif)
Okay so i removed the center air dam plastic to get this lip to fit but im still trying to get some other pieces out of the way. Need to figure out what some of these plastic pieces are hanging down and how to remove them
3 series lip didnt work out.
Any other members with the sti lip on the base bumper wanna give me some tips or pics of where you bolted the lip to the bumper? I cant quite figure out the best placement
abpmerg (06-29-2014)
The following 2 users liked this post by jkopuffs:
CLtotheTL32 (06-30-2014),
Undying Dreams (06-30-2014)
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
Is it me or does the lip in this pic look like is doesn't quite make it to the wheel well part of the bumper? Like it doesn't quite wrap all the way around the bumper? I'm interested in doing this mod. Would make a great addition to my car. Just wanna make sure it'll work before spending the money. Oh and I don't have an oem lip on mine.
I hate to say it, but it does look kind of ugly. Especially on the base with the oem lip on it already, like above. Looks like there are gaps where the oem lip juts in on both sides, and even if they were done perfectly spaced on both sides, it would still look silly. Two lips is over kill.
Two lips aren't overkill when one is an OEM kit and the second is a splitter.
That splitter simply doesnt fit correctly with the OEM kit. A correct size splitter looks good on almost any car.
![](http://cdn3.bigcommerce.com/s-o22ejh/products/107/images/418/SPLITTER_V1__90746.1409034394.1280.1280.jpg?c=2)
Any splitter should fit similar to this in order to look correct. Here the STI splitter, the one being talked about here, sits about an inch wider than the bumper.
So of course it will look bad on a car that is wider than that.
The splitter under that, by aeroflow dynamics, sits even wider, how a splitter should sit.
I can guarantee if the splitter fit the TL like it did this suby, it would look great.
Try doing what one TL owner did and buy 2 lips at 50 a pop and cut them at like a 60/40 and 40/60 ratio then connect the two 60% pieces to make a wider splitter.
Or contact aeroflow and have them machine you an aluminum splitter that fits for like $300.
EL BAN (11-15-2014)
