Starting Issue
Starting Issue
I have had the same starting issue happen to me for the second time in row. I went to the gym around 5:15 am this morning and started up the car and the car started up as normal. I left the gym and went home around 7:00 am and the car started up normal. Then I left home to go to work around 8:00 am and went to start the car and there was a slight hesitation. The car didn’t start as quick as it would normally when I turned the key. I had to leave the key in the turn on position slightly longer than usual. This is the second time this happened to me. It happened yesterday and today after I came home from the gym on my way to work in the morning.
I turned the car off both times and it started up normally.
Do you all know what this could be and how to resolve it?
stick or auto??? def have the battery checked but I had my starter replaced once before at 40k...if the dealer u bring it to has a good tech he will test the output of the starter and check the teeth on it before considering replacement....as well as check the battery
cycdaniel
Dec 17, 2019 10:58 AM
