install of air filter
Old Feb 25, 2009 | 06:21 AM
Esco5710's Avatar
The search function isn't working for me. I keep getting error messages and "stopword" msgs.. Is there a thread on how to change/ install the air filter on a 2005TL?? Thanks.
Old Feb 25, 2009 | 06:35 AM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
cabin or engine?
either way just google it and add Acurazine to the search words.
Old Feb 25, 2009 | 07:13 AM
blkaspec's Avatar
Full of water...
https://acurazine.com/forums/3g-tl-2004-2008-93/diy-replacing-cabin-air-filter-3g-garage-diy-f-130-a-583555/
https://acurazine.com/forums/3g-tl-2004-2008-93/air-filtration-3g-garage-diy-f-130-a-555135/
https://acurazine.com/forums/3g-tl-2004-2008-93/cabin-filter-replacement-mod-3g-garage-f-130-a-591437/
Old Feb 25, 2009 | 07:27 AM
Esco5710's Avatar
engine.. Im replacing the cabin filter too but I already saved those instructions..
Old Feb 25, 2009 | 07:34 AM
vinnier6's Avatar
open airbox take out old and insert new....its that easy...i believe there is like 6 screws to take out...
Old Feb 25, 2009 | 07:36 AM
Esco5710's Avatar
It's really that simple?? I figured it would be more involved since everything else on this car seems to be hidden. Thanks!
Old Feb 25, 2009 | 08:04 AM
blkaspec's Avatar
Full of water...
sorry, i figured you had issues with the difficult one
yeah, its pretty simple. the flex hose is a little stiff and you may need to wiggle things around to get proper access, but its just a few screws...
Old Feb 25, 2009 | 08:27 AM
rockstar143's Avatar
4 screws to be exact...make sure you have a LONG screw driver for the back right one.
Old Feb 25, 2009 | 10:13 AM
MichaelBenz's Avatar
CTS-V Import Slayer
10MM on a speedhandle for the win!
Old Feb 25, 2009 | 11:12 AM
SouthernBoy's Avatar
Registered Member
There are also two plastic "clips" that secure a plastic conduit which runs along the rear (throttle body side) of the upper housing. You need to remove those from their inserts as well.
Old Feb 25, 2009 | 01:36 PM
TheChamp531's Avatar
Chapter Leader (San Antonio)
Just take off the 4 clips along the Air Filter housing and 4 Screws, pull the housing up, then take out old filter and put in the new one. This is probably the easiest things you can do on your car besides adding fluids!
Abe_Froman
Sep 16, 2015 01:27 PM
Skirmich
Sep 15, 2015 06:41 PM
Aleax
Sep 9, 2015 08:04 PM
sputik
Sep 7, 2015 01:40 PM
bymotion
Aug 31, 2015 05:00 PM
