Snow?!?
Old Dec 1, 2003 | 04:40 PM
hasema's Avatar
Snow?!?
Can i drive this car up to the mountain? I have bought cable chains? Do you recommend a different tire?
Old Dec 1, 2003 | 05:13 PM
erikmoeser's Avatar
If you have the Potenza 030s you are out of luck. The Turanzas should go in snow if not too much and not too steep....Good luck. Check tirerack.com for recommended snow tires if that is an issue for you.
Old Dec 1, 2003 | 05:39 PM
Yaaro Dhana's Avatar
I have used Bridgestone Blizzak WS-50 tires before. They have very good grip in ice and snow and are quieter than my all-seasons. Tire rack has them for the '04 TL for about $150 each. I am looking at getting them for my new TL.
For your reference, where we live, we get about 70 inches of snow a year. It is also fairly hilly.
Old Dec 1, 2003 | 05:44 PM
MikeRadio's Avatar
What if you live in a "normal" area where you get winter like normal... maybe a 2 foot snow once or twice ayear.. possibly one big blizzard..l but other than that not alot.
Is it ok to use the stock tiores that came with the car?
Mike
Old Dec 1, 2003 | 06:27 PM
We had a snowstorm a few days before I took delivery -- the salesman said that he was driving around with the stock tires quite nicely and the stability control kept things under control. If we didn't get quite this much snow, I would probably be tempted to stay with the stock tires (then again, with the vibration issues on the Turanzas, a switch to snows may actually be a good thing )
Mike
Old Dec 1, 2003 | 06:37 PM
I ordered the 18" wheels with ml new TL and they come with Yokohama tires. Anyone know how those perform in the occasional 2-3" of snow?
Old Dec 1, 2003 | 07:25 PM
crazymaxe's Avatar
I have the blizzaks on mine here in alberta. So far snow ice and wet weather driving has been excellent. And there quiet too.We had a 6 inch snowfall 2 weeks ago and it was like having all wheel drive.
6mt
psi
36 front 34 rear
Old Dec 2, 2003 | 12:21 PM
SlntSam's Avatar
I'm getting Dunlop DS2's installed today. Had to drive this morning in the snow with the RE090's and it wasn't pleasant. Gave the ABS and VSA quite a workout.
Old Dec 2, 2003 | 01:07 PM
warccm's Avatar
I have Dunlop Winter Sport M2's - gripped real nice this morning. Some **** in an SUV tried an over take from the right lane at a red light - eat my snow dust, those suckers held tight to the road. Mr. 4Runner was quite surprised I blew right past. :smokin:
Old Dec 2, 2003 | 01:08 PM
HacksawHilliard's Avatar
They won't.
Old Dec 2, 2003 | 04:54 PM
erikmoeser's Avatar
I called the tirerack and 17" wheels for snows are out of stock until mid January. I may venture out in snow with the 030s but not if I can help it. There is nothing quite so unnerving than having the ABS chatter away with absolutely no retardation of speed and sawing the wheel back and forth with absolutely no change in direction! And trying to get going on level ground and barely being able to do it. The 030s may not be that bad but two prior experiences with Potenzas (040s and RE71 I think) don't bode well for safe and sane winter driving with the 030s.
Old Dec 2, 2003 | 05:05 PM
jdone's Avatar
Mike
Mike, if you live in Baltimore (or Louisville) I think you mean 2 inches and not 2 feet. Yes, the stock all-season radials will be fine unless you live on a very large hill.
Old Dec 2, 2003 | 05:15 PM
BolderKeith's Avatar
The Blizzaks work surprisingly well on icy Colorado roads, and not well in snow that is 12 inches or more deep. For good going in deep snow it takes either mud and snow tires or chains. The Blizzaks do not corner well on dry pavement, something we expect from our TL's.
On a car I owned previously I put Blizzaks only on the driving wheels, and cornering was dangerous so I had to add Blizzaks to the other wheels. That made the cornering bad, but al least predictable.
Old Dec 3, 2003 | 12:18 AM
MikeRadio's Avatar
We had two feet last winter....
But that was once in 3 winters. who knows.
I am going to keep the stock ones on.
Also, can someoen answer this.
My old car had traction control and ABS not this VSA.....
In the snow when I was stuck ina parking lot, I would deactivate the Traction control so the wheels would spin to get out of the spot.
My dealer says that since this has VSA that I should NOT disengage if I am stuck in aparking spot with the wheels spinning.
Is this correct??
Mike
Old Dec 3, 2003 | 08:59 AM
With 2 feet of snow, if uncleared, I wouldn't bother venturing outside with my TL, snow tires or not .
The dealer seems to be incorrect. VSA plays a role in correcting understeer and oversteer in turns by adjusting engine power and braking. It shouldn't have much (or any) role to play when you are coming out straight in a low traction situation; the traction control would be a factor, though. In my experience, letting the wheels spin to get out of snow is not the best option. I typically try clearing as best I can around the tires and "rocking the car" back and forth to gather a little bit more momentum, if necessary.
Is this correct??
Mike
neuronbob
23
Jul 16, 2019 10:48 AM
johnalfa
Oct 31, 2015 12:55 PM
Ponsey_Scheme
Oct 23, 2015 09:16 PM
dirleton
Sep 19, 2015 02:12 PM
jaimbot
Sep 17, 2015 09:25 AM
