Slight surging while cruising
Whats up Acurazine,
My car surges slightly when I'm cruising between 37 mph - 40 mph. Enough that I can feel it. Has this happened to anyone? No check engine light on.
Thanks!
Thanks!
Are the RPMs jumping around? Or just a slight surge under steady throttle?
See if it does it while cruise is engaged. If it does not, then I would assume the APP sensor would be the first thing I would be looking at.
My car used to surge around 45 mph (5th gear 1500 rpm).
Replacing PCV valve fixed my problem.
Checking your PCV takes a few minutes, so you can quickly eliminate that possibility.
https://acurazine.com/forums/third-g...urging-966184/
Yeah I can see the RPMs jump about 2-3k. Ill try and see if it does it when the cruise control is on. If it doesnt happen when the cruise is engaged where should i look next?? any ideas.
thanks for the tips.
What he said. You must have skipped over his advice. Look at replacing the APP sensor.
Sutitan
Nov 28, 2009 06:36 AM
