Simple question
Old Sep 4, 2010 | 02:12 PM
absolute_jdm's Avatar
Simple question
will the 07-08 bumper's 3G fit an 06? cause the parts guy at my local acura dealership said they wouldn't cause of the it mounting points or something like that.. he also said the same thing for the headlights. I was wanting to swap out my 06 front bumer for an 07-08 and get the 07-08 A-Spec lip.. so i was wondering if it was possible? Thanks -Jol-
Old Sep 4, 2010 | 02:31 PM
PowerCommander's Avatar
Yes it can be done. If there's a will there's a way . In all seriousness... I also have an 06 TL and I know some members here have done it I just can't recall which member. If you search "A-Spec" and have alot of time you might find it. But i'm very positive it's been done. I'm actually looking to do the mod myself but not sure if it'll cost alot cause I'm still debating on which A-Spec (04-06 or 07-08) to get. Most seem to preffer the a-spec for the 04-06 and I aggree as well that it does look better heheheh.
Old Sep 4, 2010 | 02:40 PM
con5tant's Avatar
simple answer : yes
Old Sep 12, 2010 | 12:30 PM
vipTL's Avatar
Illist
Hit up Flipside he did the conversion
Old Sep 12, 2010 | 01:51 PM
VQPower37's Avatar
i believe the mounting points for the headlight were different for the 04 05 compared to the 06 and up (i think)
so since you have an 06 it should be plug and play hopefully others will chime in and confirm, or tell me im totally wrong lol
Old Sep 12, 2010 | 04:51 PM
Trunk Monkey's Avatar
Coolest A-zine Member
I think the grille and a few other things are different on the 04/05 so you have to get those (not sure exactly what) things along with the bumper to do a conversion. Now I'm not sure that's the same case for the '06....I know there's a thread about this if you try to search b/c I wanted to do this also. There's a few places that have the bumper for around $200 but you'd have to buy the fogs, wiring, new grille, etc...so it's gonna be a decent amount after said and done. Plus I can't do an install b/c I don't have time, so that hurts the cost also
Old Sep 12, 2010 | 05:24 PM
VQPower37's Avatar
x2 ... to do an entire 07 front end conversion is def going to be pricey unless u can find all used parts painted to the color you need, and install them yoursefl
Old Sep 13, 2010 | 05:18 PM
thanks for all the info.!!!
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
rboller
Sep 23, 2015 02:49 PM
