Side Mirrors???
Old Dec 22, 2004 | 07:03 PM
AbiNY's Avatar
7th Gear
Side Mirrors???
After the Below zero storm we had here in NY my side mirriors dont work right, i dont think its frozen cause i can make the mirrors to move down and right but not up or left on both sides. Also my rear view mirror auto glare is not working , Anyone else had this happen to them . thanks for any feed back
Old Dec 22, 2004 | 07:13 PM
NFLblitze1's Avatar
Youse Gots Sacked
is this on both mirrors? or is it just one...because if its on both then it might be a technical issue where it has to do with wires as oppose to broken mirrors....or it could be that you arn't doing something correctly...
Old Dec 22, 2004 | 07:37 PM
92NSX's Avatar
Haven't had any of those problems. Have only had the use the defroster for mirror a couple of times here if FL though so they don't get a real workout.
Old Dec 22, 2004 | 08:31 PM
rets's Avatar
Moderator Alumnus
Have dealers checked!?
In its coldest day this week, I was parking my car in the lot. Everything seemed fine, and even all my 4 windows worked ok. IMHO, our cars should be able to work well under this temp...
Old Dec 22, 2004 | 08:46 PM
Ron A's Avatar
Administrator
The side mirror problem sounds like a bad switch, if they both won't go up or left on both sides.
Does the green light come on for the inside rear view mirror when you push the switch? Of course, the cold has nothing to do with this mirror.
Old Dec 22, 2004 | 08:58 PM
Dr.Murdock's Avatar
What part of yonkers you from? 3G TL? What color? I'm the one with the NBP, i drive it around a lot.
As for the mirrors, dont know what could be the problem. But that same weather froze my drivers side window shut. The back half closer ot my should would og down a bit, but the other half closer ot the windshield wouldnt budge.
Old Dec 22, 2004 | 09:02 PM
AbiNY's Avatar
7th Gear
Yes its on both mirrors
Old Dec 22, 2004 | 09:05 PM
AbiNY's Avatar
7th Gear
Yes its on both side mirrors ,
Yes I think its a Bad switch cause mirrors go down an right
No The Green light does not come on when you push the button for the rear view
I am From Yonkers Ave By BronxRiver Road its NPB
Old Dec 22, 2004 | 09:28 PM
Acuraluvr's Avatar
Spinnin them beats
if the green light on the rear mirror is not lighting, its a tech. prob, git it checked!!!
Old Dec 23, 2004 | 02:00 AM
tl_soso's Avatar
Blue is so so
AbiNY - OMG - I was gonna post about this problem as well - Because I have the EXACT same problem you're experiencing. And I'm about 10-15 minutes away from Yonkers - in Riverdale right by the henry hudson.
I noticed this problem myself yesterday - my read view mirror's green light is not coming on anymore and its not working properly. AND both my side mirrors are only working 50%, just like yours. And when I reverse, neither mirror goes down and I have tried with both sides selected.
This is pretty weird. I know we got hit with a cold day the other day, so could this mean that the cold screws around with the electronics in this car?? Very serious problem, no? I am gonna get this checked at my next service, which isn't for another month or so.
Or should I just do it now? What do u guys think?
AbiNY - I go to Acura of Westchester, what about you?
Old Dec 23, 2004 | 07:57 AM
DarkWraith33's Avatar
Team Nighthawk MechE
Both of you need to call and make an appt... Definately a weird coincidence though.
Once both of you get this fixed, I am very interested to hear what Acura had to say/what they did about the problem.
Please keep us posted!
Old Dec 23, 2004 | 08:37 AM
RockBlocker's Avatar
Weird, Hope you get it solved
Old Dec 23, 2004 | 04:24 PM
tl_soso's Avatar
Blue is so so
I also noticed this yesterday....... My memory settings are no longer working either!!!! I cannot set my settings and the system is not recalling my previous ones either.
So there are a total of four problems taking place here. Are u also having this issue as well AbiNY?
Old Dec 23, 2004 | 07:57 PM
AbiNY's Avatar
7th Gear
Yea my memory setting is not working either and also my windsheild sprayer isnt spraying i dont know whats gotten into my TL getting all these problems. I got an app. for tuesday up at Heat acura in wappinger falls my friend works there so hell take care of me there .
Old Dec 24, 2004 | 01:24 AM
tl_soso's Avatar
Blue is so so
Holy crap!!!!!!!!!! mine neither!!!
I thought the windshield sprayer was not working because there was no more cleaner in it, but you're right, this is out of function too. I checked and I do have cleaner in there.
So this is just insane, I hope there aren't any more serious electric problems with the car, cause a fire or anything like that.
Keep me posted, I will be making my appt today.
1. Side mirrors only have 50% functionality/limited movement
2. Side mirrors do not move down when reversing
3. Windshield sprayer not working
4. Memory Settings not working
5. Rear view mirror deflector not working
All seem to be due to the cold weather we had here earlier in the week.
Old Dec 24, 2004 | 01:03 PM
tl_soso's Avatar
Blue is so so
kjh
Old Dec 28, 2004 | 09:24 AM
stock95accordex's Avatar
I have the same problem w/my side mirrors. I have a dealer appt. tomorrow.
Old Dec 28, 2004 | 09:56 AM
GUMP's Avatar
GOLDEN NUGGET
It sounds like everything is just frozen. It has been very cold in the East the past couple of evenings. Especially the windshield washer...mine didn't work the other day, but as soon as it warmed up, it worked fine. I'm going to buy the below zero crap you can use so it doesn't freeze up. Keep us updated.
Old Dec 28, 2004 | 03:41 PM
tl_soso's Avatar
Blue is so so
its a blown fuse - most likely. i go in tomorrow - will let u guys know what caused it, wat the fix is
Old Dec 29, 2004 | 10:09 AM
NGNOUS's Avatar
Count me in on the same EXACT issues....Here is a link to a thread that I started and have since redirected to this orginal thread.
]https://acurazine.com/forums/showthread.php?t=106013[/URL]
Old Dec 30, 2004 | 06:02 PM
tl_soso's Avatar
Blue is so so
yep - blown fuse!!!!!!!! I just got mine fixed yesterday. everything is back to normal now.
apparently, if the wipers are stuck on ice and u try to operate them - they blow the fuse to prevent the wiper mechanism from damaging itself - this fuse happens to control these other things as well.
At least this is what the dealer told me.
Old Dec 31, 2004 | 11:03 AM
NGNOUS's Avatar
Thanks for the update!! Did the dealer inform you which fuse number was blown?
Old Dec 31, 2004 | 12:47 PM
TL42's Avatar
Thanks!!
TL soso
Thanks for the update on the wiper - mirror connection.
Points to you for the info
TL42 - Gord -
Old Jan 4, 2005 | 12:34 PM
SIAcura's Avatar
My dealer says it's the # 20 fuse.
Old Jan 4, 2005 | 12:57 PM
tl_soso's Avatar
Blue is so so
ahhh sorry, I was in such a rush I didn't even inquire. but good luck!!!
Old Jan 14, 2005 | 09:35 PM
destin's Avatar
9th Gear
This posting has been so helpful. We drove up from Florida to Ohio over the holidays during a deep freeze and I must have tried to use my wipers once or twice. Needless to say, I had the same damn problem, wiper washer wouldn't work, seat memory wouldn't work, and two out of the four rear window adjusting directions wouldn't work. As you all just said, it was indeed a blown fuse, #20 which is a 7.5A fuse. There is a spare under the hood if you need it. And I thought my hardwired radar detector had caused the problem... whew!
Old Jan 14, 2005 | 10:39 PM
chusteveb's Avatar
WOW!!! YES, once again you guys are so helpful. Thanks for saving me a trip to the dealer, my time, and any misshaps that could've (would've) happened! I'll now be freeing the wipers from the glass if I even suspect them to be frozen to the glass. Thanks guys!
Old Jan 14, 2005 | 11:08 PM
rets's Avatar
Moderator Alumnus
Old Jan 17, 2005 | 10:01 AM
chusteveb's Avatar
Interesting thing was that the wipers still worked despite the fuse being blow so I wonder how this would protect the mechanism. Just a thought. But at least everything works now. Thanks!
Old Jan 21, 2005 | 09:08 AM
badboy's Avatar
Same problem here, thanks to this thread I don't have to go to the dealer....now this is why I love this site...
Old Jan 27, 2005 | 06:24 AM
brantleylancaster's Avatar
7th Gear
Is the fuse box containing #20 under the hood or is that just a box where the spare is? I have the same problem now... Thanks for saving a trip to the dealer.
Old Jan 27, 2005 | 11:12 AM
badboy's Avatar
the fuse is inside, next to the hood opening latch, the spare is under the hood, so is the fuse plucker....caution, there is only one spare, so do not try to do this when the weather is still below freezing...
Old Jan 27, 2005 | 11:42 AM
x-mode007's Avatar
I had the same exact problem right before X-MAS. Took the ride to the dealer and they said after 3 hours of keeping me that a multiplexer and some other parts have to be ordered. So they ordered and I waited. The parts fianally came in mid January and they installed them. BUT the service rep said the Tablet PC they use to program the Multiplexer has crashed and they cannot program the thing to make my mirrors memory seats........ work. I thought that was BU*^&*^%.
So i got really pissed and called another dealer in the area and they said bring it in right now and they will fix it within 10 minutes.
Turns out to be a FUSE..... long story short the other place did not have a clue on what they were talking about.
Old Jan 30, 2005 | 02:06 PM
quake97's Avatar
I would also like to add I had the same problem. Replaced fuse #20 on the interior panel and now all is good again. It's amazing that one fuse controls all that stuff. I also find it funny that this fuse handles half of the controls for the side mirrors.
Joe
Old Jan 30, 2005 | 03:46 PM
gitRplyr09's Avatar
TL Driva
Question turn signal mirrors?????
on the topic of side mirrors... has anyone done/heard of the TSX side mirror conversion with the tl.... the tsx mirrors have the turnsignal in them... i want to do that to my tl, but i dont want to get screwed over with shitty aftermarket mirrors that either 1) wont fit right 2)wont look good or 3)wont even work at all... so if anyone has any info about this... let me knoW!
Old Jan 24, 2009 | 08:47 PM
tgt's Avatar
tgt
Gentlemen (if you are still on the board, 4 years LATER) -
I wanted to pass along my thanks for this thread. After MUCH searching I happened upon this thread with the EXACT same issue I was having. I had already tried the fuses, but didn't even check #20 (at 7.5amps and the label I didn't pay any attention to it), so I wouldn't have checked it had I not read through this.
Thanks again!
-tgt
Old Dec 31, 2011 | 02:19 AM
Fauch's Avatar
8th Gear
Thanks for this thread. Thought my windshield washer fluid was frozen, then realized I couldn't even hear the motor of the washer going. Then realized my sideview mirrors had limited power (couldn't move them left), thats when I clued onto this thread. Fuse #20 inside the car was blown. Replaced with 10A and it's all good again
rockyboy
Aug 4, 2024 10:35 AM
Type S Zero
Feb 17, 2016 02:37 PM
guitarplayer16
Nov 29, 2015 02:03 PM
sockr1
Oct 1, 2015 01:31 AM
