Should I double tape it?
I'M BACK!!!
same prob
is it torn or just hanging down? i had the same thing happen to my car, it hung down right there on the part by the moonroof/ someone got a lil rowdy and yanked it down a bit, i thought it was bad but there is a thread on here about it, just look around somwhere. It says to either:
1. replace some clips it has, they dont stick anymore and you need new ones
2. the clip/sticky isnt holding right and all you have to do is push it back up and it will snap back in place
thats what happened with mine, i just popped it back into place and it stuck on good and havent had a problem since. just my
I would recommend taking it to the dealer and tell them to do something better than new clips. This is an ongoing issue with the 4th gen headliners. I myself have had numerous trips to the dealer and each time they just stuck some new hook and latch adhesive clips, but after several days in the sun/elements they just slipped off again! They went so far as to replace the entire headliner and to no fail, it drooped again. Finally they got a little innovative and decided to use epoxy like substance and it has stuck since (knock on wood). Go to the dealer and request something more permanent. Good luck.
Fool
03-10-2016 08:42 PM
xsilverhawkx
09-28-2015 06:51 PM
09-25-2015 06:14 PM
