Seatbelt tip
Seatbelt tip
My problem is my seats are positioned so that the buckle wont really fit between the seat and the b-pillar. I don't want to rub a hole in the side of the seat either. I found that if you let the buckle retract, and then pull the buckle to the top by the plastic clip it will stay. Works grea and minimal effort if you don't cosntantly have passengers. I like to keep it up there to prevent any noise from jostling around and prevent seat damage. Just and idea. Slide it right to the the top!
Originally Posted by Dkrudop
Great suggestion! I was having the same problem.....knew I was gonna end up with scuff marks on the b pillar sooner or later! Thanks!
Been doing the same thing since I saw my wife's '02 has her pillar by the seatbelt all dinged up...so I have been taking the extra time to do exactly what you described...so far it is paying off big time.
I have been doing this since I got my TL because one of the TLs that I looked at before I purchased mine had about 10 scuff marks on the passenger side. Looked like crap. This does work but is a bit of a pain in the butt to always think about. For those of you who do get these scuff marks, my Cust Ser rep has some type of solution that he put on mine to cover one up - it helped a lot but the scuff is still there. And, unfortunatly it does nothing to protect it.
He also gave me a very good suggestion but I have not tried it yet. One of his female customers sewed a little "knob" right at the point in the belt that will keep the buckle above the seat - said it worked like a charm. Have to try it out.
Originally Posted by boltjames
Do you use Tidy-Bowl® or another cleaning product?
Originally Posted by PoochaKannInc
I Zaino my bowl. It gives it that shine I'm always looking for...nearly blinds me when I try to aim and shoot at times...
Okay, I took it too far. I'll stop now
I aim too, but suck and have to clean the toilet a lot anyways
Great tip, moreace. Sliding the buckle to the top is one of those really simple ideas that works!
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
