seat memory has alzhiemers!!
Old Feb 3, 2005 | 10:06 PM
weissbrewer's Avatar
Question seat memory has alzhiemers!!
Every couple of days my tl seat memory getrs erased?!?!?!anyone else have this problem?
Old Feb 3, 2005 | 10:09 PM
kosh2258's Avatar
Known issue...
This is a known issue with early TL's. Take it to the dealer and they have a TSB to address this problem under warranty.
TSB = Technical Service Bulletin
Old Feb 3, 2005 | 10:15 PM
clay8898's Avatar
yeh, i had the same problem and the dealer took care of it . i think they said it was the ecu.
Old Feb 3, 2005 | 11:13 PM
jafo's Avatar
Team Anthracite Member
Sometimes when I unlock the car it doesn't switch to #1... After my wife has locked it with the #2 FOB. Anyone have that happen?
Old Feb 3, 2005 | 11:15 PM
Ron A's Avatar
Administrator
Originally Posted by jafo
Sometimes when I unlock the car it doesn't switch to #1... After my wife has used it with the #2 FOB. Anyone have that happen?
Is your keyfob linked? When you use it to unlock the doors, does the MID say "Driver 1 detected"?
Old Feb 4, 2005 | 02:20 AM
triggle's Avatar
'04 6mt Pearl
Do we have a definative test for this known bug ?
If the symptoms are repeatable could you please describe in detail how to duplicate the problem. This would greatly help others diagnose the same ECU problem common to this model year.
Sorry if this is regurgitating old stuff but it may be useful to have links to a diagnostic for this problem within this thread. I fear I may need it soon as well.
Old Feb 4, 2005 | 02:27 AM
rets's Avatar
Moderator Alumnus
Exclamation This is the original TSB for early build... for the reference...
https://acurazine.com/forums/showpos...18&postcount=6
Appendix...
Thanks. cblackburn.
Old Feb 4, 2005 | 02:31 AM
jafo's Avatar
Yes. Most of the time, it does work. It's not worked probably 2-3 times. The service bulletin does not apply to my '05 TL #17700. Anyone seen this happen on their '05? So far it's not too bothersome, I just press the #1 button on the door and wait for the seat to move. Unfortunately my wife is pretty small so the seat takes a while to move into my position... But so far it hasn't happened enough to make me worry too much. Hopefully it won't progressively get worse...
Old Feb 4, 2005 | 07:17 AM
Thanx for the info! Now off to my nearest dealer 100 miles away!
Old Feb 4, 2005 | 07:20 PM
pettydw's Avatar
On 6MT's: the parking brake has to be on between setting changes, otherwise you get stuck with your spouses memory settings.
Old Feb 4, 2005 | 07:27 PM
jafo's Avatar
Very interesting! Not gonna run outside, anybody know if this is documented in the manual? Or just a "feature" (read defect).
Old Feb 4, 2005 | 07:52 PM
Ron A's Avatar
Administrator
Owner's Manual, page 94: Notes for vehicles with M/T:
      Old Feb 4, 2005 | 08:05 PM
      jafo's Avatar
          My wife remembers setting the parking break because a co-worker was in the car, and she had to "be careful" since his leg was right there...
          Still kind of a mystery!
          MrHeeltoe
          20
          Feb 23, 2023 01:54 PM
          tsx_boy
          Dec 13, 2019 08:33 PM
          MrHeeltoe
          Sep 29, 2015 10:43 PM
          hashbrown
          Sep 29, 2015 12:13 PM
          MrHeeltoe
          Sep 28, 2015 05:43 PM
