Scraping The Bottom!
Old Feb 26, 2004 | 07:17 AM
Angry Scraping The Bottom!
Hey is it just me is it everytime my TL goes down slop head first, it scrapes the Air Vent under the body? Its this plastic bar thing if you look from the front of the bottom of your car. Its like this plastic strip, well mine is scraped up PRETTY BAD. It seems like I scrape it 2-3x a week. Everything is stock, I didnt lower it or anything, it just seems like my old car has a lot more lift than my TL. Do I need to replace it?
Old Feb 26, 2004 | 07:35 AM
mcm244's Avatar
Re: Scraping The Bottom!
It was not installed improperly. This air vent is typical of Acura vehicles. I had the same problem with my '95 Integra. During the blizzard last year, there was a block of solid ice attached to the air vent. When I tried to back out, the front panel actually started to come lose.
I have been very careful with my TL. I avoid parking nose first and hitting the concrete blocks. In addition, I have been trying to avoid going down a hill that suddenly levels off (as opposed to small inclinations) and scapes the air vent.
Mark
Old Feb 26, 2004 | 08:15 AM
Sherlock's Avatar
I scrape mine all the time too.. unfortunately the grade of our driveway does it.. but now I'm very cautious of parking blocks and sidewalks. I've gotten it down to a mininum, but still do it. Our car is partially a bottom breather so it's just an inevitable evil.
Old Feb 26, 2004 | 08:52 AM
NathanSilver's Avatar
Sacraficial element on the car?
"Something has to go."
Just kidding.
My car does it as well--geometry effects.
I kringe every time it happens.
Still not desensatized from the 04TL Experience...
NathanSilver
Old Feb 26, 2004 | 09:26 AM
jdimaria's Avatar
I have scraped mine also. I have to pull out of certain drive ways going the wrong way just so I don't scrape the air vent
Old Feb 26, 2004 | 10:46 AM
6speed's Avatar
Same problem here. My driveway is steep. It's more a problem backing out. I found if I turn the wheel and come out on an angle it doesn't happen.
Old Feb 26, 2004 | 11:14 AM
RunSilent's Avatar
I've run into the same problem, and have adopted 6speed's approach.....take the spots where the incline changes as slowly as possible and always at an angle.
Old Feb 26, 2004 | 11:15 AM
VTEC=happiness's Avatar
What's a TL?
Odd...mine is lowered yet I almost never scrape
Old Feb 26, 2004 | 11:53 AM
JoganJani's Avatar
never stops!
Me too. My driveway is the reason I'm not lowering further than stock. I've to be very cautious and drive at an angle goign up and down the driveway. And Yes! I also had 95 Integra and had to install the clips at least 10 times due to parking over a cement block commonly available on most of the parking lots.
Old Feb 26, 2004 | 12:16 PM
fsttyms1's Avatar
just try not to go straight at inclines and declines. go at a slight angle to help reduce the amount that you scrape
Old Feb 26, 2004 | 12:52 PM
moeronn's Avatar
is learning to moonwalk i
Have any of you noticed much scraping on speed bumps? I'm looking seriously at the TL, but the parking garage at my work has several nasty speed bumps and I don't particularly want to be scraping the car several times a day, every day. They are almost as high as parking blocks and are pretty steep and pointed at the top.
Old Feb 26, 2004 | 12:55 PM
twonce4u's Avatar
I had the same problem. You aren't scraping the car though, there is a black thing under the car that hangs down that is what is being scraped.
Old Feb 26, 2004 | 12:56 PM
6speed's Avatar
So, what is the pupose of the black thing?
Old Feb 26, 2004 | 01:17 PM
Lore's Avatar
CEO, Team Anthracite
The black thing forces air up into the engine compartment.
Old Feb 26, 2004 | 01:20 PM
DC5_Integra's Avatar
Team Nighthawk Water Boy
Is it a must to have on?
Old Feb 26, 2004 | 01:26 PM
Mr Zipps's Avatar
When you go up a incline the best way is to go on a angle. You will rarely scrape if you do that... If you go head on with a incline you will scrap 95% or the times...
Old Feb 26, 2004 | 01:33 PM
Old Feb 26, 2004 | 01:46 PM
kona's Avatar
Maybe not, but you do want your engine running as cool as possible don't you? My wife's car has this too. It's my 'early warning notification' that she's just pulled into the driveway. :p
Old Feb 26, 2004 | 02:32 PM
Lastdra900n
Guest
Posts: n/a
i did it like 3 times in one day, ever since then ive been really really careful and so far everythings good.
Old Feb 26, 2004 | 03:11 PM
rets's Avatar
Moderator Alumnus
Exclamation
Slow down is the way to prevent this happening.
If you scratch this everyday, you will not be the driver for A-Spec package or lower your suspension kits.
I use it as the early warning, too, as kona said.
Old Feb 26, 2004 | 08:35 PM
daikon38's Avatar
Happened to me once as well. Since then, however, I've been super super super careful, and hasn't happened since. :o
Just like someone else said, approach the speed bump or dip at an angle.
Old Feb 27, 2004 | 02:03 PM
user 37364638's Avatar
BOOK EM
My car`s lowered and only happened once, pulling too close to a snow pile. Other than that, no problemo. Just think about it next time it looks like the area might be in question, and sloooow down!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
KBTypeS
25
Oct 1, 2015 04:49 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Desert Ridge
Sep 27, 2015 02:37 PM
