Running Fogs W/ out Headlights using Stock switch?
I have a 3000K HID kit I want to install as Fogs in my 06 style headlights. I want to rewire the fog lights so they are completely independent of the headlights but are still controlled by the OEM switch. I have searched and searched all I see is the DRL module which does not solve my problem and suggestions on running a separate switch. Please tell me someone has rewired the the HID/FOG wiring allowing for independent operation?
Only difference is that I do not have fogs... I have DRLs instead.
Don't know how much different it is from the American TL since the DRLs get turned on automatically with the engine and turned off when the lowbeams are on.
I've managed to get an independent switch allowing me to turn on/off my DRLs whenever I want. Only issue for me is that I have a DRL light in my display now.
I can try to write you a DIY tomorrow...
I have done something similar.
?? I dont want a separate switch I want to use the OEM foglight switch but I want it to function on/of regardless of if I have my headlights on or not.
Not sure doesn't sound the same, all you have to do to accomplish what you did is wire a switch between the power of your DRL correct? I need to most likely rewire where my fog lights get its switched power from. Currently I imagine it is switched or powered from a relay off the headlight circuit. I could figure it out i'm sure going through the wiring diagrams but it seems like someone would have done this already.
The fogs most likely do have it's relay powered from the lows. The first time I did my lights... I set it up that way. My DRLs came on only with my lows.
If you can locate the relay and get it's power from something than you should be good to go.
Yup read through those threads as well no resolution to what I want to do it looks like the only possible option is to tap into the switch directly at the switch before it goes into the control module then run the switch off a relay and the accessory of your choice. Wish I didn't have to be the guinea pig on this one I find it had to believe this hasn't been done!
I did this so long ago I don't remember in detail. Basically, I sent a ground signal to the fog relay via an additional switch. This bypasses the Fog module. Cool thing is, it's easily removable to go back to stock, and doesn't mess with the factory wiring at all. I remember using the OEM switch would have took much, much more time. The combination switch wiring is not quick & easy to get at. But, it's very do-able.
Run a wire from the ground at the stock switch the the ground on the fog light relay. Very easy to do, but you just have to remember to turn off the fogs because they wont automatically shut off w/o the switch. But that would be the case if you put in a seperate switch anyway. Just did this on my TL and works perfectly.
mada51589
Jan 9, 2025 04:40 PM
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
