RPMs dropping at WOT
This happened to me 2 times till now. I have a 5AT TL-S and when im going WOT on third gear at around 6k the rpms drop to 5.5k and start climbing back up. Third gear is long so you can really feel the rpms dropping for a sec. All the other gears work smoothly. I have CAI and ATLP Cat-Back. Should I be worried?
itz the torque converter.... lock-up/semi lock-up stage.... at 6k rpm... itz slipping.. semi lock-up... then when it locks up.. both input and output moves at the same speed.. which drops it back down to 5.5k....
Sounds out. I'd offer to test mine, but 6,000 rpms in 3rd is like 80+ mph, right? I need some clear freeway and won't see that for the next couple of days, at least.
depending on the actual situation, this can be normal. I won't worry too much about it...
you will see if more often.. even at slower speed.. if you cruise 60mph on 5th.. then add throttle, sometimes u will see the needle drop a bit then come back up..
as long as u are not getting Tranny issues (flashing D) you should be fine
Originally Posted by stillhere153
not to sound like a dick but... could it be the car shifting from 3rd to 4th
cuz I mean you didn't specify you were in ss mode
Originally Posted by MWalsh9152
it sounds like the torque converter locking up to me.
coz it is more common to see it starting at maybe 3.5k(semi lock up) and just jumps to 4k(lock-up) when u are accelerating.
but maybe because of the high rpm it can do the reverse.
emailnatec
29
Sep 28, 2018 04:27 PM
DerrickW
Nov 15, 2015 05:52 PM
4drviper
Sep 23, 2015 07:42 PM
