Rough starts????
Old Feb 25, 2004 | 03:49 PM
  #41
Tripp11's Avatar
Newbie for Life
Originally posted by jimthegreek
I had the same issue with my vehicle for the first 2 weeks i had it. Took it back to the dealer and had them check it out. They replaced the keys and the vehicle immoblizer unit and had not had that problem ever since...
He did state that could be one of the problems. I presume I will see how many more times it does this and then propose your solution to them.
Thanks, jimthegreek. I appreciate your candor and dealer insight into issues!
Old Feb 25, 2004 | 04:15 PM
  #42
Blue Frog's Avatar
I have been having the same problems. Last week when I took my car in the service mgr said something about it being normal and that is was actually a safety feature!
Sounds like the they are going to handle this like the tire issue (which by the way - Acura agreed to replace mine).
Old Feb 25, 2004 | 04:33 PM
  #43
Tripp11's Avatar
Newbie for Life
Like the vibration issue, the more this starts coming to the surface the sooner Acura will realize that a solution may need to be formulated for this problem.
Old Feb 25, 2004 | 04:45 PM
  #44
Skeedatl's Avatar
Lurker
I'm wondering if it has to do with the high compression...perhaps the weenie starter just doesn't cut the mustard.
Old Feb 26, 2004 | 08:01 AM
  #45
Sherlock's Avatar
If it is the immobilizer, try eliminating the common causes of it: no other metal rings that might have flipped over and touch the key, another immobilizer type key on the same key chain.
Mine sometimes doesn't start in 1/2 second like my Accord and other cars do, but I've learned to crank it for 1 second now and it's never failed, mine is just showing the results of the emissions stumbling. And being a vin #259 I've had my share of problems, luckily this isn't one of them.
Old Mar 5, 2004 | 08:52 PM
  #46
ArcticFormula's Avatar
I have a only 100 miles on mine and on 3 occasions is has not started on the 1st try. Today it took a 3rd try to get it started. A bit embarrassing since I was showing my boss my brand new car. I have read this thread and other one I saw here on the subject, and all of the reasons stated for this seem plausible, but only one person mentioned (think he said a weenie starter), I also wondered, is this starter really up to the task? I wonder if it's the same part they use for the smaller TSX motor?
Regards,
Old Mar 5, 2004 | 09:01 PM
  #47
vtechbrain's Avatar
Its only 3 to 5 seconds, come on guys are we running out of Ritalin?
Old Mar 6, 2004 | 02:30 AM
  #48
Pushing_Tin's Avatar
This is a brand new $35k car! Not a 1980 Ford Escort. Why some of you continually give Acura a free pass on some very sketchy and crappy design flaws is beyond me.
Old Mar 6, 2004 | 02:36 AM
  #49
Lastdra900n
Guest
Posts: n/a
hey guys, ive been following the the "wait for the cpu to check everything out" method and ive gotten an idle period of about 2 secs before it starts. but if i crank it right away its fine.
Old Mar 6, 2004 | 07:55 AM
  #50
TimC's Avatar
The quick reference guide indicated that the slow start could occur due to the engine's mangement system to cut down on the emmsions which occur at teir peak during start up
Old Jun 3, 2010 | 10:23 AM
  #51
Ruby's Avatar
US Navy Seabees
I am having the same problem with my car. I'd say its about 50/50 on the start ups. Somes it'll just fire up and the rpms will go to like 1.2k and back down to 1k or 900k and idle. Other times it sounds like it sputters and its "trying hard" to ignite. Its weird. Still no solution for this huh? Emissions my ass.
Old Jun 3, 2010 | 11:32 AM
  #52
HokAy's Avatar
yeah ive been noticing this too BUT only when i start it up in the morning or for the first time since last use which was from at 11ish pm and start up at like 10ish oclock in the next day and it does sound like a rumble when i crank it but it only last for like 3-5secs and goes into idle. then after driving around and coming back to the car and restarting it again it fires up just fine......Might do the seafoam to the car since after my first seafoam.
Old Jun 3, 2010 | 11:55 AM
  #53
mrsimeon's Avatar
startup a bit of rough idle
I am having a rough idle and you can feel it when the car is started over night or after the Acura TL 2004 has been sitting for a long period of time.
Has anyone else found out how to figure out a solution to this problem?
Does the Fuel filter need to be replaced?
I have 79K miles on my Acura TL 2004 6 spd.
any in site or comments please.
Old Jun 3, 2010 | 05:12 PM
  #54
hondadna4's Avatar
I'M GOING IN
I have had the same problem ruff it would crank over and take forever to start got my car dignoised today at the dealer it was the fuel pump. 470 dollars later it starts like a charm bring it to the dealer.
Some people will say I can afford to bring it to the dealer but I say If you cant pay the price to have a luxuy car maybe you should get a KIA
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
scionxb3003
Sep 14, 2015 01:52 AM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
NSolace
Sep 3, 2015 08:14 PM
