Road Noise in a TL
Road Noise in a TL
I'm most likely going to get a 2005 TL with auto and navi. The only thing that I found that I didn't like too much (everything else I love about the car) is the road noise on highways.
Can I do anything about that like adding a different tire with a quieter tread? I realize I will sacrifice some road grip for a softer tire.
Is there something that can be done to add insultation around the trunk or in some gaps in the car to try to lower the noise?
Is not a big noise but it's noticeable when you are also comparing it to a C240 or a Infiniti G35 which are also contenders.
Any advice or suggestions would be great. Love this forum. Glad I found it.
I would start with tires.
Moderator Alumnus
For my preference, I didn't like G35 sedan and coupe I tested drove last summer, they're noisy.
Back to TL, although I dislike EL42s Bridgestone tires, I think they're very quiet. If you get better performance tires, the noise could go up rather than low. IMO.
Would you consider to test-drive another 05TL? (I test drove 3 04TLs, the first one was terribly noisy and unbalanced.)(a few ppl felt 05TL suspension is stiffer than 04TL's, will this be the factor of noise control...?)
1 Post
Turn your hearing aid down.
Gratis dictum
When car shopping, I drove the TL and G35 back-to-back on the same afternoon. The ride quality, both smoothness and noise level, was much better in the TL Handleing went to the G35, interior to the TL, exterior to the TL ergonomics to the TL, and lastly value, to the TL. The G35 is a great car, but not for me.
Onalake,
Everybody has different tolerance levels. Factors like road surface, car/tire combination, and comparisons with other cars come into play. I am like you-found the tire roar of the EL 42 objectionable but have gotten somewhat used to it now. If it wasn't going to cost $600 plus I would have replaced mine already. Messing with the sound proofing of body, cabin etc will not do it. Its the tire pattern and construction. To think that they cost $220+ and have gotten godawful reviews from users is pathetic!!Do not understand how this substandard piece passed the famed Acura quality control? But check out the Tire Rack site. They evaluate ride and road noise based on feedback from customers. Not always to be totally trusted but can useful in picking the right tire. I like the ratings on the Pirelli Nero, Yoko AVS DB S2, Michelin Pilot Sport PS2. Might switch over to one of these before too long. And absolutely do get the TL!
noise comment
If you are getting the navi model, they all come with the michelins instead of the EL42's. I dont know if they are any better, I read in another thread that someone said they were only marginally better, but nonetheless michelins are always better than bridgestones in my book. I bought my 05 TL navi about 3 weeks ago and im pretty happy, but I too noticed some noises while on the highway. Not only road, but I get some hefty wind noise from my door area that is pretty well spread out, thus i cant pinpoint one spot. when I get my first oil change, I will mention these noises to them....jason
Not a Blowhole
Camry's are always available - if you want a tomb, buy a Lexus.
It would not be easy to materially change the nature or ditsrbution of the TL's overall sonic profile.
I have measured the TL's noise with a portable FFT Spectrum Analyzer, and it is competitive with the published specs of the world's best sport sedans, and better than the 3-series. Wind noise is very low.
Of course, noise perception is not a static figure. A decibel reading does not come close to determining subjective response, which is determined by the DISTRIBUTION of the frequencies generated by the powertrain, the tires, and quality of the door seals, and the like. Each person has a different subjective response to this distribution - some equate a bit of road noise with a sporting demeanor, while some yearn for a Lincoln Town Car or a LS400.
The biggest factor on road vibration is how soft the bushings are, especially in the sub-frames. Make them jello-soft, and you can get the quiet, Novacaine effect. But the TL's road manners would be greatly compromised. Add a ton more asphalt-insulation into the A,B, and C pillars, and you increase weight at the expense of performance and economy. Anyone willing to check that one on the Options list? Not me.
The other factor is of course, a vehicle's inherent rigidity - this is measured by its characteristic resonant frequency: the higher it is, the stiffer the overall platform. It is this characteristic which helps impart the "ingot like" sense of structural integrity which we perceive as a safe and well-constructed vehicle. As I recall, the TL's CRF is higher than the 3-series or the G35.
It's all about balance- the time to decide what car has the least amount of tradeoffs is before the purchase.
Spinnin them beats
Originally Posted by Repecat
They are fairly quiet, but are not a very good tire. They flatspot when left overnight, are subject to hydroplaning, and are next to useless in the snow.
we havnt switched tires yet.... snow on mon!!! i think i may need 2 get new tires for my dad for christmas cuz hes wont get it for himselF!!!!
What a shame... they used to be much better than that (actually they were the tire I chose to keep from hydroplaning when I had my old Civic and they worked great).
05/5AT/Navi/ABP/Quartz
05, no flatspoting here with the Mics but it has only gotten down to mid 30's. Car is not silent like a tomb, not designed to be and I don't want it like that. You can check the Db level in various road test at different speeds.
Are you looking at the right vechicle? I don't thinks sport/lux = silent.
Received 2,329 Likes
Want tomb-like silence?
Get an ES330 or RL.
Get an ES330 or RL.
Get an ES330 or RL.
Get an ES330 or RL.
When I test drove cars I brought my sound meter with me. Essentially every car at 75 mph had the noise level of 75 decibels plus or minus a couple. This was true for six or seven different makes including the TL. However, the TL seemed quieter then lower price cars because the frequency distribution was different. Note, the salesmen were quite amused wound my wife told them to keep quiet I need to test the sound level!!!
Team Nighthawk MechE
As I thought...
I've had 3 Accords prior to my TL, and the noise in them didn't get to me until this last one... Noise was a BIG thing I was looking for in getting a new car. I guess in my old age, I needed some peace and quiet.
Compared to my Accords, as I expected, the TL is leaps and bounds more quiet. I think I still expected a little more, but I am pleased with where it ended up.
(I can't say I've been in an ES330... Im intrigued now that everyone says it's a TOMB...)
Not a Blowhole
"Of course, noise perception is not a static figure. A decibel reading does not come close to determining subjective response, which is determined by the DISTRIBUTION of the frequencies generated by the powertrain, the tires, and quality of the door seals, and the like. Each person has a different subjective response to this distribution - some equate a bit of road noise with a sporting demeanor, while some yearn for a Lincoln Town Car or a LS400."
Get an ES330 or RL.
Get an ES330 or RL.
I test drove the RL and found that it was more quiet than the TL but not AMAZINGLY quiet. If I didn't know about the active sound technology, I would have just attributed the quiet cabin to extra soundproofing. I guess the technology works better on paper.
Moderator Alumnus
I don't like the seats in the ES 330 and the interior electronics are not as good. RL is just not worth the money. TL has great electronics. No one else matches them yet so that's a big reason for getting a TL. It just would be nice to have it quieter inside.
The car magazines, such as Car & Driver, post dB levels for most test drives and the TL got 67db. This level fell at or below competive cars in the C&D March 2004 comparison.
The EL42's are quiet on most surfaces, but I have noted the Dunlop M3 winter tires are more consistant on all surfaces, though a bit louder overall. The EL42's can get quite loud on specific surfaces that the Dunlops seem to ignore.
I test drove the HPT optioned car back to back with the base EL42 car and the HPT car had more tire noise and suspension harshness per my and my wife's impressions. The HPT treadwear rating is about the same as the E42's, so the above and poor winter traction are the main drawbacks.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
