Reverse/ back up lights hid kit help
Old 08-05-2009, 11:09 AM
  #41
22ontl's Avatar
how can i make the switch to work? how do i run the wires for the switch?
Old 08-05-2009, 03:21 PM
  #42
wolverine27's Avatar
Originally Posted by Elegant TYPE S
Rodney is the man.. I hounded him when i did my project .. LOL. I ran into problems because of the stupid DEI 528T relay I decided to use which was defective. Anyways you should buy the timer delay relay to make ur life easier and just wire it in that way.
I also like RODNEY wired it up to the cup holder for a tailgater switch. RODNEY really deserves credit for this mod.
And those of you who dont get the power of HID.. watch:
http://www.youtube.com/watch?v=Qvjx4dxfOzU
And this is a video of ABP04TL hitting the tailgater switch.. BACK OFF!!
http://www.youtube.com/watch?v=VK345...eature=related
Hello,
do you have a different switch for this second video? for the back up light?
how's the power working? is this will not drain your battery if you have too much HID?
thanks...
Old 08-05-2009, 03:54 PM
  #43
1075's Avatar
I would be leery about mounting the ballasts in the trunk and putting the liner back in over top of them. I'm guessing that you used some sort of double sided adhesive to mount them since they are on the underside of the trunk sheet metal. My concern is the heat from the ballasts, the sun heating up a dark color car over time and the vibration will eventually bring the ballast down on the underside of the felt trunk lining.
Old 08-05-2009, 05:58 PM
  #44
1fsthatch's Avatar
lol
Old 08-06-2009, 01:05 AM
  #45
Being an Acha Bacha in
Elegant TYPE S's Avatar
100% safe... absolute no problems with heat.. I use 3M VHB tape and you can ask, many people who have seen this setup.. they can hang off those ballasts that's how strong they are stuck on there. No heat issues what so ever.
Old 08-06-2009, 01:10 AM
  #46
Originally Posted by CUCU28
WIRED IT UP USING THIS RELAY KIT FROM EBAY Item number: 320395282848 IT WAS EASY AND IT DOES NOT FLICKER, AS SOON AS CAR GOES IN REVERSE MY HID KIT TURNS ON BOTH BULBS WORK AND IT IS BRIGHT, I LOVE IT. I DO NOT SEE THE NEED FOR A DELAY IN IT BUT THAT IS JUST MY PREFERENCE. I ALSO HAVE A SWITCH MOUNTED IN THE CUP HOLDER TO BE ABLE TO TURN THEM ON WHILE THE CAR IS ROLLING TO BLIND THE COPS WHEN THEY TRY TO CATCH ME....HEHEHE I DON'T DRIVE SLOW SO I NEVER WORRY ABOUT TAILGATERS...
Awesome! Another HID Reversed TL!
I think the delay timer is an absolute must because you do not want to cause the flicker effect every time you go from Park to Drive or Drive to Park .. because this is just a big no no for HID's. This wouldn't be a problem for LED's or halogens.
The 2 second timer, prevents exactly this. I wouldn't recommend doing it any other way. Without the timer.. you aren't going to cause any serious damage, only thing that will fry is your ballasts or bulbs prematurely. So you'll end up replacing your equipment sooner then expected. The delay timers are about 10 bux I think.. very cheap.
I just rewired my crap again after I installed a new backup camera last week... very easy. I'm tempted to go near the airport and pop my trunk open and see if I can land some airplanes..
Old 08-06-2009, 08:52 AM
  #47
dwb993's Avatar
^^How about some pointers on wiring this up, please?
Old 08-06-2009, 02:39 PM
  #48
StYLeZz101's Avatar
a wiring diagram with the momentary switch would be highly appreciated
Old 08-06-2009, 03:52 PM
  #49
I need a car in
thait's Avatar
did you run a power wire from the battery all the way to the trunk?
Old 08-07-2009, 12:22 AM
  #50
Sorry guys I can't provide wiring diagrams for atleast 2 weeks.. I'm slammed with work and in between the moving process. I can try my best to answer questions whenever I can.
As far as running a power wire from the battery, I did that for my amp, so I was able to grab power from my distribution block in the back. I would highly recommend grabing power from the battery or else you will fry your stock wiring cuz the current draw on start up is a lot for those little wires to handle.
Old 08-07-2009, 12:24 AM
  #51
The momentary can be used to either trigger the timer relay or the 2nd relay directly.
Old 08-10-2009, 10:55 PM
  #52
I need a car in
thait's Avatar
thanks elegant, but i was wondering as the 528t only provide 15amp of juice that isnt enough for the two hid kit does it?
Old 08-15-2009, 03:27 PM
  #53
I need a car in
thait's Avatar
any update elegant =]
Old 03-07-2010, 11:00 AM
  #54
www.grounded4life.org
mikey3.2's Avatar
Can someone tell me what relay I need and what 2 second time delay I need? Also how do you wire up the switch for tailgaters? thanks!
Old 03-16-2010, 06:50 PM
  #55
Phmbm12
Phambam12's Avatar
i always thought you just put it in reverse
Old 03-16-2010, 08:11 PM
  #56
dwb993's Avatar
Mikey, search for the DIY by bzyrice. I don't think it has been added to the 3G Garage yet. The delay timer is the "528T Timer SPDT Relay".
Old 05-11-2010, 11:34 AM
  #57
mikey3.2's Avatar
Thanks! I found the link but it dont have the wiring info I need..
Old 05-11-2010, 11:35 AM
  #58
mikey3.2's Avatar
Does anyone know how to wire up the DEI 528T relay for the reverse HIDs with a 2 second delay???
Old 05-25-2010, 04:20 PM
  #59
mikey3.2's Avatar
Old 05-25-2010, 09:30 PM
  #60
Carfreak
carfreak55's Avatar
Do we only need 1 DEI 528T or 2?
Old 05-26-2010, 04:48 PM
  #61
dwb993's Avatar
You should only need one.
The wiring diagram they ship with the unit is so tiny it is unreadable. Here it is in PDF:
http://www.the12volt.com/installbay/...&term=DEi+528t
There is another diagram PDF showing the remote start delay wiring.
I have not begun this project yet, but I believe we need to use the instructions for the Remote Start Delay. So you would connect the OEM green reverse light wire to the black w/stripe trigger input and the brown to the trigger input of the HID relay.
Please, someone who knows something about this check out the diagram above and correct me if I'm wrong.
handsom-hustla
11-13-2015 05:04 PM
pozebly
09-23-2015 07:30 AM
nuldabz
09-03-2015 05:49 PM
pesobreeze
1G RL (1996-2004)
09-03-2015 12:26 PM
voigt
09-02-2015 10:44 PM
Quick Reply: Reverse/ back up lights hid kit help
