Resistor Installation for LED Switchbacks
hey AZ, quick question on the resistor installation:
could anyone give me a detailed (but simple) explanation of the resistor installation? I've seen the DIY on here and it just says "connect" the resistor to the ground and turn wire, but how exactly does it "connect"? Do I have to strip down the wires, take out the wire from the headlight connectors and run it through the blue splicers? Also the left headlight seems to have 2 red wires and one black wire...
I have the V-LED switchbacks and resistors.
thanks everyone
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
thanks everyone
2004 Acura TL
I had a member on here do mine. He told me when they are properly installed the resistor will warm up fast, thats a good indication you have done the job correct!
Fearless DIY Guy
The blue clip will have two 'channels' - one channel will be open on both ends, the other closed on one end. Insert the resistor wire into the closed end. Insert the BLINKER wire on the headlight (Blue w/ red stripe on driver, white on passenger, IIRC), and clamp down. Repeat this process and connect the other clip and resistor to the ground wire...so your resistor goes BLACK ---> RESISTOR ---> BLUE/RED -or- WHITE
AZ Community Team
Received 7,771 Likes
thanks for the responses guys ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
okay so I did it, pretty simple and clear, however; when I try my turn signal, the inboard dash just displays a constant Left turn signal (I have only installed it on the left signal so far, right one is still the normal bulb), and the LED doesn't turn on at all, any help?
EDIT: nevermind, switched the LED around and it works GREAT, thanks for everyone's help
Greengecko
09-16-2015 08:19 PM
03, 2004, acura, correct, install, installation, led, lights, resistor, resistors, strip, switchback, switchbacks, taps, tl
