Replacing Highbeams ??
Old Sep 3, 2005 | 12:47 AM
kcrumbley's Avatar
Question Replacing Highbeams ??
Can anyone guide me through the process of replacing the stock high beams? I know how to replace the fog lights but not sure about the high's. Thanks 05 TL
Old Sep 3, 2005 | 01:54 AM
446's Avatar
446
I do the shifting
Why are you needing to replace them? The HID bulb is low/hi, as a single unit.
Old Sep 3, 2005 | 02:09 AM
Iceman23's Avatar
Certified Hater
i agree
Old Sep 3, 2005 | 02:27 AM
kcrumbley's Avatar
Oh then I'm a . Thanks
Old Sep 3, 2005 | 12:00 PM
massr1's Avatar
same bulb, two filaments
Old Sep 3, 2005 | 12:04 PM
Donte99TL's Avatar
Does anyone read this
Same bulb but there is a flap that flips up letting more of the light out for the high beam.
Old Sep 3, 2005 | 12:13 PM
SouthernBoy's Avatar
Registered Member
Xenon lamps do not use filaments as in incandescent lamps (halogen lamps are incandescent). There are no filaments in a High Intensity Discharge (HID) lamp.
The headlamps on the TL are of a bi-level design. To go hi-beam, a flap is raised in order to emit more light from the HID lamp.
Old Sep 3, 2005 | 12:48 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
Exactly. In fact, you can hear the "clunk" of the shutter moving, if you're standing near the headlights when someone toggles the highbeams.
Old Sep 3, 2005 | 12:56 PM
kcrumbley's Avatar
Oh well I guess I'll switch out the fog lights and return the high beams. Thanks for the Info.
Old Sep 3, 2005 | 01:06 PM
Registered Member
The fogs on the TL call for HB4 lamps. These are also known as 9006's. For an excellent choice, consider Philips Premiums. These are very good lamps and will offer superb fog lighting. You can order them from www.autolamps-online.com.
Old Sep 3, 2005 | 04:43 PM
Thorin78's Avatar
Previous Owner
if you feel that your lights are not "bright" enough, you can adjust the level. same if you feel they are too low or something. I would try to be considerate of others if you're raising them or replacing the bulbs for brighter ones.
Old Sep 3, 2005 | 07:12 PM
crazymjb's Avatar
Yeah, xenons are arc based, which in theory makes them more durable(no filament to break, and I believe if they were 100% leak proof would last indefinatly as I don't believe the xenon is affected by the arc, the transformer is another compnent which under normal circumstances won't burn out).
Old Sep 4, 2005 | 07:06 PM
massr1's Avatar
^ oops, thanks for the clarification
Old Sep 4, 2005 | 09:05 PM
EmuMessenger's Avatar
Wow, I thought this thread was a joke.
Glad the questions were answered.
Old Nov 9, 2012 | 10:59 AM
dkerz's Avatar
Is is necessary to remove the bumper to replace the foglights in a "05 TL or is ther an easier way to repalce them
Old Nov 9, 2012 | 11:43 AM
Trunk Monkey's Avatar
Coolest A-zine Member
holy hell!!
This has to be the oldest thread bump I've ever seen!
Old Nov 9, 2012 | 11:47 AM
Bearcat94's Avatar
AZ Community Team
G-034: DIY: New Fog Lamps in 15 Minutes
https://acurazine.com/forums/ramblings-12/ladder-theory-97658/
G-022: DIY: Replacement Fog Bulbs
https://acurazine.com/forums/showpos...3&postcount=46
https://acurazine.com/forums/religion-politics-18/boring-96036/
https://acurazine.com/forums/automotive-news-6/nissan-dunehawk-debut-frankfurt-motor-show-%5Bsketches%5D-109748/
csmeance
Jan 7, 2026 06:25 PM
cycdaniel
Dec 17, 2019 10:58 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
niray9
Dec 8, 2015 07:34 PM
Billu99tl
Sep 13, 2015 11:30 AM
