Replacing the "fog lights"
ADVANCE DRIVER
How hard is it to replace the stock bulbs in a 04 TL for the Fog Lights in the overall headlight? I am wanting to replace the stock light bulbs with something..brighter. The manual show's the left light you need to take the air intake(?) top off? but nothing to the right. Anyone done this? and is it easier to do than the manual makes it seem?
Full of water...
i had a CAI in when i did mine and it was only hard because i was doing it in the dark. it only took like 5-10 tops. but not sure how the stock intake plays in to that, sorry. what are you thinking about putting in there (brand, color, etc)?
SpenceTLMonster (01-12-2012)
Correct for the driver's side you need to take a part of the intake off. This pops right off then there is a tube which is below that piece that pops off as well. Without removing these components of the intake you would pretty much have no room to access the bulb area. The passenger side is a breeze compared to the driver's side since it is easily accessible.
On the 04 base tl there are no lower fog lights in the bumper.. Do u have to buy a insert for fog lights or would u actually cut out a spot for a set? I couldnt find any inserts on ebay and was wondering how I would go about installing a set?
Chapter Leader (Houston)
NO need to remove intake or anything to install fog light bulbs. As for lower fogs, you'll have cut your lower grilles to fit the accord fogs. There are several threads around here with detailed instructions.
ADVANCE DRIVER
Not sure what brand yet, going to check some lights out soon, but I know I want to do a HID WHITE, no blue. Don't want to look akward with mix match color coming from headlight.
ADVANCE DRIVER
See, very true. I mainly don't like that yellow color cause I think it seems cheap/basic but I do know safety and well road conditions are what I got to abide by...but I see so many people with such illegal looking lighting I figure I can get away with some whiter lights haha.
ADVANCE DRIVER
its not hard at all to replace the factory fogs on the 04-06 model. i swapped mine for 5000Ks to be as close a match to the OEM headlights. even my accord fogs are 5000K. quite good in the fog I must say.
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
