Replace Shift Knob
Old Jul 31, 2011 | 10:28 PM
darknighttl05's Avatar
Replace Shift Knob
Looking to buy a new shift knob but I read on here that if it s not the factory one the boot will fall down.. Is there a aftermarket shift knob out there that has the clip so I dont have to mod the boot.
Old Aug 1, 2011 | 12:45 AM
Toddy's Avatar
Registered Member
I dont think there is. Someone made a few custom ones a while back but he doesn't do em anymore. You can put a zip tie around the shifter under the collar to keep it from sliding down. Or you can do what I did and cut the shifter down about an inch and then use a countersunk knob. My boot can't go anywhere now.
Old Aug 3, 2011 | 08:47 AM
jrocka312's Avatar
A-SPEC 6MT
I found the solution for you. About a year ago, I did this custom job... check it out...
https://acurazine.com/forums/3g-tl-problems-fixes-114/possible-solution-6mt-owners-hanging-shift-boots-aftermarket-knobs-791802/
Old Aug 3, 2011 | 09:19 AM
maharajamd's Avatar
^I was under the impression that part is no longer available??
Old Aug 3, 2011 | 11:07 AM
jrocka312's Avatar
A-SPEC 6MT
It is discontinued...and has been for a long time, but I was able to locate a few of them. Try locating it using the part number...you never know where they can turn up.
mada51589
Jan 9, 2025 04:40 PM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
lland
Oct 4, 2015 04:47 PM
ibGTV
Sep 28, 2015 03:40 AM
HOWELLiNC
Sep 5, 2015 03:09 AM
