Remote Start
Old Feb 11, 2010 | 03:04 AM
vovka2007's Avatar
Remote Start
Hi. Anyone out here knows if it's possible to stick a remote starter on a manual car. I heard someone did it, but not sure. Anyone done it? help appreciated.
Old Feb 11, 2010 | 08:23 AM
nfnsquared's Avatar
Yes. There are several RS brands that are designed to work with MT: DEI (Viper, Clifford, Python), Comustar, Autostart. There's a good DIY in the audio forum for a DEI install. It was for an auto. There are slightly different wiring hook ups for a MT that are detailed in the install manual. Don't recommend DIY if you are not electrically smart. Do a search for: "Very detailed", use the quotation marks.
Old Feb 11, 2010 | 09:16 AM
corduroy's Avatar
Yeah you can... the wiring is a bit different but I did my own work on a AT 06 TL for a Viper 5901. Cutting the ignition wire is pretty scary!
Old Feb 11, 2010 | 09:19 AM
corduroy's Avatar
oh and these links might help you...
/forums/f72/very-detailed-install-viper-5901-remote-start-87562/
http://www..com/showthread.php?t=2550681
http://www.the12volt.com/installbay/...39&KW=acura+tl
http://www.the12volt.com/installbay/...50&KW=acura+tl
Old Feb 11, 2010 | 04:42 PM
weas's Avatar
CBP 6MT
I have a remote start on my car, had it installed at a local shop though. The only thing about having it on a MT is when you're shutting your car off you have to make sure you follow a certain procedure. (which you get used to, and for the most part, do anyway.)
1.) Hold the brake
2.) Make sure car is in neutral, and pull the e-brake
3.) Let out the brake
4.) Hit the remote start button within 15 secs.
Now when you take the key out the car will still run, but when you close and door and lock it, the engine will shut off. If you unlock the car for any reason, i.e. to get something out of the back seat, you can't start up with the remote start. I guess it's a safety precautions so you don't accidentally put the car in gear and then use the remote start.
Good luck!
oyayjoe
Jan 1, 2019 10:17 PM
oyayjoe
Sep 12, 2015 04:40 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
datadr
Sep 2, 2015 06:46 PM
