Rear view mirror on a 2004 TL
Old Nov 1, 2017 | 08:47 PM
Joecop67's Avatar
Forgive me if this is posted in the wrong place. My rear view mirror seems to have a darker tint to it than other rear view mirror I'm used to. Mainly my 2013 Camry and my 2008 civic.
Is this normal? It seems slightly grey or greenish.
Old Nov 2, 2017 | 12:40 AM
Superunknown's Avatar
Make sure the auto dimmer is off. There's a button on the bottom of the mirror.
Old Nov 2, 2017 | 04:22 AM
Joecop67's Avatar
I tried that. Makes no difference if it's on or off. The best way to describe it, it looks tinted. I may try to take a picture of it.
Old Nov 2, 2017 | 08:57 AM
Jackass's Avatar
It is not as "clear" as a manual mirror. It will have a slight tint to it. The real question is if the auto-dim is still working or not...
Old Nov 2, 2017 | 09:27 AM
Joecop67's Avatar
I don’t know if the dimming works or not.
So auto-dimming mirrors are not as “clear” as regular ones? I’ve never had an auto-dimming mirror.
Mia there a part number for a regular one? Lol
Old Nov 2, 2017 | 09:30 AM
take a flash light to the front of the sensor. the mirror will automatically darken.
I love mine, since trucks like to be lifted and have all kinds of front lights, all I have to do is hit the switch and the mirror will darken
Old Nov 2, 2017 | 09:55 AM
Sounds normal
Old Nov 2, 2017 | 10:32 AM
Joecop67's Avatar
I had tried with an led flashlight. I saw no change.
Old Nov 2, 2017 | 10:33 AM
Is the green light on?
Old Nov 2, 2017 | 10:44 AM
guitarplayer16's Avatar
I wouldn't say it's a common problem but these auto dimming mirrors do get stuck regardless if the button is pushed.
My rear view mirror is stuck with a bluish tint when it used to be clear as a mirror without auto dimming.
Joecop67's Avatar
Yes.
Old Nov 2, 2017 | 10:46 AM
Joecop67's Avatar
So, you are saying it could be stuck on dimming?
Anyway to get it unstuck?
Old Nov 2, 2017 | 10:49 AM
Joecop67's Avatar
I’m meeting someone near me on Saturday with a 2008 tl they are parting out.
Would the mirror from the 08 work on my 04?
Also would the fog lights in the number of the 08 work on mine? Should I start a different thread for that?
Old Nov 2, 2017 | 10:51 AM
Joecop67's Avatar
According to an online site, the mirror from an 08 should work.
Old Nov 2, 2017 | 10:59 AM
yes, just pop off mirrors along with electrical connection; then re-install the same way
Old Nov 2, 2017 | 12:51 PM
There's no way I know of to get it unstuck.
Many Acuras share the same rear view mirror - they should all work as long as it looks the same.
I too am experiencing the same problem - back in 2010 and 2011 it's VERY noticeable when you hit the button on and off. You'd be blind to miss it working.
it hasn't bothered me that much, but I'm mainly a chicken to change out the mirror and not crack the windshield.
You could just browse eBay for Acura TL rear view mirrors and notice that a few of the listings have the stuck blue tint.
It should look like this though:
Old Nov 2, 2017 | 01:14 PM
I just reread your original post, if your rear view mirror is a slightly darker grey/green that sounds normal.
Old Nov 2, 2017 | 02:32 PM
truonghthe's Avatar
What is dimming mirror? I can't recall using it at all since my back window is 5%....
Old Nov 2, 2017 | 02:35 PM
I'm not cool enough to go 5%...
Old Nov 2, 2017 | 03:02 PM
Joecop67's Avatar
Old Nov 5, 2017 | 01:24 PM
Joecop67's Avatar
I replaced the mirror. The one on the right is my defective one.
Old Nov 5, 2017 | 01:56 PM
Wow, that's a huge difference!
Was it easy to replace?
Old Nov 5, 2017 | 03:03 PM
Joecop67's Avatar
Yes, it was. I followed the directions posted for removing the hfl, unplugged it. Then I took off the bottom cap.
I used a flat screwdriver on the top edge of the mirror and a rubber mallet to gently tap down parallel with the windshield. Carefull because the mirror will suddenly fall off.
To install it, use the screwdriver and hammer from the bottom to get it all the way on.
MomsMdX
1/2G MDX (2001-2013)
Nov 1, 2017 02:41 PM
jameswesss
Oct 30, 2017 08:17 AM
evgu-tl
Oct 26, 2017 02:11 PM
mana1015
Sep 25, 2017 04:32 PM
Jacques226
Aug 15, 2017 06:15 AM
