Rear Turn Signal LEDs
I know I need resistors.
For the rear turn signals, what color LED have you used? The tail light LED panels (running lights and brake lights) have red LEDs. Since the lens is red (06 TL with Depo Type-S tails), I should be able to use white LEDs in the signals.
My question is, does it make a difference in the output?
Anyone have experience with this?
6ohm for 2 bulbs (just the rear)
3ohm for 4 bulbs
Has anybody got any leds from JLC lighting. I just talked to Jack from JLC and he said that we can do a GB from them.
They have the Type 1 switchback white/amber leds and also Cree Led reverse bulbs.
i bought the cree led reverse bulbs. two sets actually. one for my 08 tl and one for my brothers 09 camry. its really bright and way worth it compared to 48-led reverse light bulbs or however many leds they use...
cree led is just one led but its super bright. if you look at it straight on its almost blinding. not as bright as hid reverse though
I just did rear LED turn signals and front switchbacks. Use red, make sure you test the bulb before you wire things in. The light output is lower in the daytime, but still visible (although this depends on what type of bulb you get). It's much better at night.
Land of 10,000 lakes
Yes: http://www.v-leds.com/BlinkerWarning...orLanding/true
3ohm for 4 bulbs
3ohm for 4 bulbs
All About Trance
I'd be interested in this group buy (after getting proper approvals from the AcuraZine gods ).
rockyboy
12-06-2022 02:29 PM
